07-20-2009, 10:21 PM | #1 |
Newbie Join Date: Dec 2008 Location: Kihei,HI
| losi mrc problem
hi! im a newbie into rccrawling..i have a losi mrc with holmes hobbies torque mini master and just recently something went wrong with my mrc. if i push the throttle my rc wont move but the steering is working... what you guys think is the problem? thanks for your respons!! here's some pics.... Last edited by JeepCJ5LosiMRC; 07-20-2009 at 11:09 PM. |
07-20-2009, 11:44 PM | #2 |
Rock Crawler Join Date: Jan 2008 Location: P-TOWN
Check your connections from the ESC to the motor. But honestly it sounds like you smoked your ESC.
07-21-2009, 10:41 AM | #3 |
Newbie Join Date: Jul 2009 Location: Roseville
Does the motor still run?? If so your slipper may need to be adjusted. Also you will want to get metal diff locks as the plastic ones will strip out quickly and add a metal locked center spool as the plastic one will also strip out soon enough. The next part in line to strip out from high torque will be the drive shafts. MIP makes a replacement that won't break. |
08-08-2009, 08:18 AM | #4 |
Rock Crawler Join Date: Mar 2009 Location: Frisco, Texas
IM QUOTEING THIS OFF THE MANUAL FOR MY MRC!! 1.motor plugs loose 2.motor wires broken 3.esc damage my tip: check the sauldering |
08-08-2009, 08:24 AM | #5 |
Newbie Join Date: Feb 2009 Location: Germantown
Check the brushes on the motor. If the springs aren't holding them tight against the comm the motor will not run. One of the springs could have popped off. It happens with brushed motors from time to time.
08-11-2009, 09:15 PM | #6 |
Quarry Creeper Join Date: Mar 2009 Location: ON THE ROCKS
are the drive shafts spinning if so then check the set screw at the axle and the drive shaft
08-12-2009, 10:09 PM | #7 |
Quarry Creeper Join Date: Feb 2009 Location: Glendale Az
plug the motor directly to your battery..........if it turns,guess what.........not the motor. Like said before, check slipper clutch for tightness , if its tight then it may be the esc....Ive had to get into a couple of these because my son would sometimes use a little too much force pulling the battery off...........check for loose wires bad solders or anything of the sort.......or duh recharge battery cuz yes we all still do that |
