07-23-2009, 11:28 PM | #1 |
Newbie Join Date: May 2009 Location: Eugene, Oregon
| Titus wheel weight question
I just got my Titus 1.9 wheels, just wondering how much each wheel weighs total with both weights in. Im thinking I want 4oz up front and none in the rear. Im running the mixer Chassis with the battery on the back plate. Any suggestions? Thanks |
07-24-2009, 12:24 AM | #2 |
Ahh I figured it out, I just wanted to make sure it was 4oz and not 8oz. Loving these wheels, just threw some Flat Irons on them. Seem to be little better than stock wheels/tires |
07-24-2009, 08:36 AM | #3 |
TN State Champ 11,12,13 Join Date: Oct 2008 Location: KTM Talk.com
If you want that thing to climb well you should be in the neighborhood of 7 to 8 ounces per front wheel. |
07-24-2009, 10:54 AM | #4 | |
Rock Crawler Join Date: Mar 2009 Location: West of Eugene, OR
More weight will be ok, but if you're still running everything else stock you might try a beefier servo and BEC first...most people eventually do anyway. Welcome. | |
07-24-2009, 11:10 AM | #5 |
Rock Crawler Join Date: Mar 2009 Location: Cottontown
No doubt, you are pushing the limits of what the stock servo can handle now. Sounds like is 645 time. That, and a BEC and about 3 to 4 more oz. up frount should have your killin it. |
07-24-2009, 11:51 AM | #6 |
Newbie Join Date: Aug 2007 Location: Lancaster
My steering servo lasted 1-1/2 crawls at the comp last weekend after putting them on mine. First round I popped a drive shaft off second round steering servo croaked Never finished either course. Also Duck Tape the weights cause if you upgrade motors and gain wheel speed the o-rings will allow the weights to expand off the rim with high wheel speed. |
07-24-2009, 12:10 PM | #7 |
Thanks for the replies. Im running a 645 already I went with the full wheel weight, 4oz in each front, none in the rear. Time to go crawlin !!
07-24-2009, 01:23 PM | #8 |
RCC Addict Join Date: Jun 2009 Location: California
You might also think about putting the lipo somewere else biseides the back plate. Try the front links of the front axle. help climbing. |
07-24-2009, 10:30 PM | #9 |
Quarry Creeper Join Date: Oct 2008 Location: Crawlin' in NorCal!
| I went with both weights up front and removed one from each rear and my rig crawls better than when I had a lot more weight. Might want to consider something other than the flat irons though, nice ride height but they don't lock up with the rocks too well. I have tried em all at this point and am most happy with the chisels. Good luck and happy crawling!
07-27-2009, 10:22 AM | #10 |
Holdin my 40oz. Join Date: May 2008 Location: Somewhere in Colorado
I also recomend the chisel's, they work great and the Flatirons seem to be too tall for most competitive crawling...as for the wheel weight issue I would personally recomend less weight than some have suggested. I run axial 1.9 beadlocks and only 3 1/2 oz. in the front with nothing in the rear and my rig can climb anything that the other guys around here (Co.) can with more weight in theirs. Only thing that is tricky is coming down off steep drop-offs , the back sometimes likes to come over the top but if you just give it a little more throttle when this happens it keeps the back end on the rocks. It is only my opinion maybe, but a lighter rig with the proper forward weight bias seems to climb very well, is less prone to breakage on falls, and has better throttle response. Overall it's driver preference, but that's my 2 cents.
