07-26-2009, 04:02 AM | #1 |
Rock Stacker Join Date: Jun 2009 Location: im in iraq
| novak mongoose
has any one used it or now how well it works thanks
07-26-2009, 08:41 AM | #2 |
Rock Crawler Join Date: Mar 2009 Location: West of Eugene, OR
Yes. Try Searching "Novak Mongoose" in an Advanced Search with Losi Mini Rock Crawler selected.
07-26-2009, 10:39 AM | #3 |
Quarry Creeper Join Date: Jul 2007 Location: Sierra Foothills
| Novak Mongoose
I have them in two of my trucks and love them. Lots of torque at slow speed and tons of wheel speed when you need it. I have updated drive shafts, tranny, and axles to hold up to the power they provide.
07-26-2009, 12:03 PM | #4 |
Newbie Join Date: Jun 2008 Location: Socal
mongoose works great even on three cell way overkill for 1.9 but its able to run on it. its programs the same as the goat. i have been running it for a while now no prob.
07-26-2009, 01:28 PM | #5 |
RCC Addict Join Date: Jun 2009 Location: California
Even though they say you can run a 3 cell don't. I burnt min up running 3 cells after a week. Run 2 cell. its still fast enough and it will run forever. Plus if you run it in a comp you can only use 2 cell anyways. |
07-28-2009, 04:45 PM | #6 |
Quarry Creeper Join Date: Mar 2009 Location: mesa
been running one since march love it glad i did it just don't use intigy driveshafts cuz the goose will snap them it is getting a little hot but what doesen't when you crawl when its 110 outside you have it all with the goose gobs of torque and power to spare plus awsome control at slow speed
07-28-2009, 06:20 PM | #7 |
Pebble Pounder Join Date: Sep 2008 Location: Anniston
| BEC related question...
If I were to run this combo with Lipo would I need a BEC also?
07-28-2009, 11:04 PM | #8 |
Quarry Creeper Join Date: Mar 2008 Location: Zachary
07-29-2009, 02:21 AM | #9 |
thanks for the help everyone
07-29-2009, 08:33 AM | #10 |
| Yes, probably. The Novak ESC is only good for a few Amps. If you're running a full-sized servo, a higher rated BEC (such as Castle's) would be a good thing for protecting your ESC from drawing too much power for your servo.
07-29-2009, 12:06 PM | #11 | |
X2 it all depends on the setup and what all your running | |
07-29-2009, 12:11 PM | #12 |
RCC Addict Join Date: May 2006 Location: China Grove, NC
I have a Mongoose in my 1.9 and I run a 5995TG servo without a BEC, no problems. A Tekin FXR with a Slider has close to the same feel and more speed and power. |
08-11-2009, 11:52 AM | #13 |
Rock Stacker Join Date: Jun 2009 Location: Agoura Hills, CA
Question for you guys running the Mongoose setup. I've ordered this for my MRC and was going to pick up a couple lipos as well. I was looking at either the 800 or 1100 mah Maxamps packs. Is the C rating on the packs really that important for crawler applications? I understand what a C rating is, just wondering if having a pack that is rated at 25c is completely overkill and wouldn't benefit a crawler motor setup. Anyone have any idea what type of run times I could expect with the Mongoose and a 800 mah lipo? |
08-11-2009, 12:19 PM | #14 |
Quarry Creeper Join Date: Feb 2009 Location: Glendale Az
seems like maybe these systems may all be just a bit different.....I definitely needed a BEC with a full sized servo.... I run a 1350 mah thunderpower and a 14 tooth pinion for comps and play around time and have had zero issues....great system |
