07-27-2009, 03:04 PM | #1 |
Pebble Pounder Join Date: Feb 2009 Location: Wisconsin
| losi mini slider
i have searched and all i have come up with that you have to do to get one of these to work in your mrc is to drill out the pinion gear. is this all? i really want to get one cause of all the good things people have said about them, and because of the cost. also i think my stocker is going to take a dump pretty soon.
07-27-2009, 04:06 PM | #2 |
RCC Addict Join Date: Jan 2009 Location: Jacksonville Illinois
I had one and would recommend a different esc. I had to dremel the mounting plate quite a bit as well. I ended up just going to the HHTMMini after about a day.
07-27-2009, 04:36 PM | #3 |
09 RCA champ! Join Date: Sep 2006 Location: Acworth, Ga
i recommend NOT drilling the pinion, but instead take a little sandpaper to the shaft of the motor while its running. that way you can use any pinion |
07-27-2009, 04:46 PM | #4 |
Quarry Creeper Join Date: Oct 2008 Location: Crawlin' in NorCal!
Ahh the motors not worth it either way you look at it. If your going for speed by all means use it, but it does not have the low end that alot of these other motors have. And if you do want to drive it around fast, plan on burning up your batteries quickly. Don't get me wrong though it is fun to play with for a minute. |
