08-04-2009, 01:54 PM | #1 |
Rock Crawler Join Date: Mar 2009 Location: Cottontown
| soundcolor and MrEd round 2
Let me preface all of this by saying there will be no video, or pics... we were to busy crawling and by the time we got around to taking pics, my battery was dead... So, lets first give a breakdown of the specs of each rig, and then we'll get to the comparo. Soundcolor rig Full miXer chassis RcBros 'red' shocks (50wt oil) Losi mini slider motor (factory spur gear, dual heatsinks) stock electronics stock battery (split into 4 cells on rear axle, and 2 in center of chassis) Hitech 645 servo RcBros servo arm custom steering links stock axles Losi steel lockers (front/rear/center) Axial 1.9 8 hole beadlocks Pro-line Flat Irons G8 MrEd's rig Kamakazi Kustoms chassis MLST shocks (white springs, 20wt oil) Insane 370 motor micro sidewinder esc futaba reciever Hitech 645 servo stock steering links stock axles Losi steel lockers (front/rear/center0 Axial 1.9 8 hole beadlocks Pro-line chisels I guess now its time to break down perfomance by individual part and give a honest opinion about which is the better product. Hopefully it will give those of you out shopping a good idea of which is the better product. Well, after about 2 hours at my little creekside rock course it became apparant. His chisels are the tire. The Flat-irons got the ground clearance, and thats about all. Those little micro-machine chisles are the shit. There is no comparison. Even tho they are small, they are killer. We each took turns with the chisels on our own rig and there is no doubt, that they ruled the day. They climbed better, sidehilled better and just flat stuck to whatever you put them on. Advantage MrEd Motor, it became obvious early on (due in part to an impromptu drag race... with rock crawlers) as to which motor was the one to have. Both had all the torque needed to get up and over anything, but without a doubt, the mini slider motor stomped the insane 370 all the way up the street and back down. I would rate them about equal as to overall torque, but there was no doubt, the slider is faster. Advantage Soundcolor Electronics. As far as this goes, all I can really say is it was pretty well a wash, he had the more expensive electronics, and his radio was waaayyyyyy cooler, but that micro sidewinder really needs a drag brake that works. There was one hill descent in particular where my rig easily, and slowly creeped down under complete control, where as the the sidewinder had alot of problems with excess speed. However, it really is a wash here because while mine had a great drag brake, his ultimatly excersises a greater amount of control over his hole system. As for the the reciever, its really a wash here too. Sooooo, Advantage... EVEN Suspension setup There was no doubt and it did not take long for it to become apparant that his springs were killing him. My full droop setup is low, and moves really well... Other than that tho, it really breaks down to the actuall shocks themselves, at which point I personally have to give the go ahead to the RcBros shocks soley because of their customization ability, you can fine tune these things till you are blue in the face. The MLST shocks are extermely good, and are just as capable as the RcBros, its just they dont have the fine-tuning ability as the RcBros Advantage soundcolor And the moment we have all been waiting for, which chassis is better. I am going to call this a wash. They are both outstanding, and there is not doubt they stomp the stock chassis so hard its not even worth comparing. The mixer chassis does have a huge tendency to get hung up on the skid, its just the nature of the beast, and running a full droop only makes the problem more apparent. On the other hand, the KK zero has a huge glaring problem that cant be overlooked. Becuase of how the upper links mount to the servo plates it allows alot of side-to-side movement, which can cause some sidehilling problems as well as for the chassis to want to get out of line. On a whole tho, I would honestly recommend either one, they are both killer. Both RcBros and Kamakazi Kustoms should be proud of their chassis, they are without a doubt awsome. Now, I will leave this open for Mr.Ed to add his comments. |
08-04-2009, 02:06 PM | #2 |
Newbie Join Date: Jul 2009 Location: Bay Area
Good read, thanks for posting. I am going to have to pick up a set of Chisels to compare to my blue Claws.
08-04-2009, 02:38 PM | #3 |
Rock Crawler Join Date: May 2009 Location: Calgary
You should really try some cut n shut Panther Cobras like Kamikaze. I made some and they rule the rocks. |
08-04-2009, 07:43 PM | #4 |
RCC Addict Join Date: Apr 2008 Location: Old Hickory
Oh boy here we go...soundcolor yer uh well yeah you kinda nailed it! both did a great job today and I don't what it is about soundcolor and pictures you tend to forget all about the camera it's just weird! I agree on the shocks I do wish I could do more with my shocks but they'll have to do for now. but soon My kk rig will be all drooped up on 90weight to see if I can get that kinda movement. This was the 1st time I've seen droop shocks in action and it was COOL! down hills were killing me with the sidewinder and the FI"S so drag break really helps out in that department. Chisels really just kick FI's Ass in the MRC crawling truely a great tire! Soundcolor has also been practiseing he was a much better driver this time then the last. miXer or KK Mini Zero if you cant drive or know your rigs limits it doesn't matter how you rig is set up. No amount of money put into your rig will cover up crappy driveing! there is some lateral axle movement on the Kk chassis but it is minimal at best and the miXer has that skid hang up issue but both chassis were a million times better than stock either one would be a great buy but the KK Mini zero is better cuz that's what I'm drivein!:-P time for us to hit a new spot and try out some new rocks and post up some more fun stuff....I mean technical information useful to the crawler scene. |
08-04-2009, 07:53 PM | #5 | |
I watched Kamikaze's rig in action at the last comp ( he uh did a little better than me uh so did gatekeeper and trace ) but that doesn't matter, ( they just got a little more practise then me...yeah that sounds good:-P) I did want to get a set of those tires they are soooo sticky it's creepy! but ( there's always a Butt ) when he was laid over on the side and you wish your tires would slip just enough to get you going again his would not. they were also larger than the blue claws ( gatekeeper and trace's tires ) and larger than the chisels. my Chisels hooked up as good and I believe I no longer want the cobras. Now if Panther tires put out a 1.9 comp tire I would definately try them out, do I have the talent to cut and shut a pair??????....let's go with........no. | |
08-04-2009, 08:34 PM | #6 | |
It was a fun time by all. Next time, I promise, pics and video | |
08-05-2009, 12:11 AM | #7 |
RCC Addict Join Date: Jun 2009 Location: California
The Chisel's . Did you use the small losi mem foam or the big pro-line mem foams?
08-05-2009, 12:21 AM | #8 |
He is definatly using the small losi foam
08-06-2009, 09:32 PM | #9 |
Rock Stacker Join Date: Jan 2009 Location: Spokane
i just want to thank both soundcolor and Mr. Ed for all of your information! I have learned lots about the MRC from both of you. I really enjoy your write ups like this as they are based of real events, But you do really need to include photos |
08-07-2009, 04:52 AM | #10 |
Yet another jab at me... honestly I dont know why I am always the one to blame... Ya know what, from now on I wont even crawl... I'll just be the cameraman. No, no... its cool. :-P |
08-07-2009, 05:18 AM | #11 |
:-P The way that I see it is that if you are having fun doing somthing, who cares if you take pictures and or video, they only add beauty to the thread and widdle out the people that never actually read the posts, so in most cases like this when you are explaning how things worked and comparing two setups, there is no true reason for them. But no seriously keep this kind of thread alive because they are the most help. I am building my rig based off of your guys experiance and recomendations. Thanks again |
08-07-2009, 05:36 AM | #12 |
thanks bro, I appreciate the kind words.
08-07-2009, 06:51 PM | #13 |
RCC Addict Join Date: Oct 2007 Location: Kennewick, Washington
08-08-2009, 04:05 AM | #14 | |
Gatekeeper and trace were both running his chassis and of course they did AWESOME! they could have probally whipped my ass with a stock MRC I would like see them run a course with thier rigs and then switch to a factory rig and see how they do! Both these guys got too much talent and I had no business trying to run with em but it was FUN. and I held my own till my transmisson exploded! Anyway, Their rigs were point and shoot just as the kk was. I honestly say that there was not a gate or a turn where I thought that a better chassis would have helped any more. I did not have a chance to drive the GC2 so I guess I really cant say for sure. both chassis were built by VERY VERY good drivers who know thier sh%t! | |
