08-12-2009, 05:29 PM | #1 |
Newbie Join Date: Aug 2009 Location: Austin
| Short wheelbase chassis???
Ok....help a newbie out! Anyone here know of a MRC chassis that has around a 7" wheelbase and 11" overall length??? |
08-12-2009, 06:34 PM | #2 |
Rock Crawler Join Date: Mar 2009 Location: Cottontown
In order to get what you want, your going to want to get a kit that has delrin links so that you can cut them to the size you need. The mixer chassis by RcBros comes with delrin links, all you will need to do is shave 1/2 inch off of each upper and lower link (the mixer sets the chassis at 8" wheelbase, 1/2 inch off of each end link will shorten the chassis up to 7"s) Now, as far as overall length, thats going to depend on what tire you are running. The larger flatirons are going to make the overall length longer than the shorter blue claws. Its up to you at that point whether to live with the longer overall length, or shorten the links further to achieve the 11" wheelbase you want. |
08-12-2009, 06:43 PM | #3 | |
I'm going to check out that chassis. The body I am using (New Bright 1:15 FJ Cruiser) is 11" bumper to bumper, wheel hub center to center would be about 7". Sorry if I posted wrong info. I want to stick with a scaler build as best I can....smaller tires. Here are some pics of what I have to work with: | |
08-12-2009, 08:39 PM | #4 |
RCC Addict Join Date: Apr 2008 Location: Old Hickory
That's gonna be a tight build. look through the MRC archieve pictures there is a guy that did what your fixing to do. I would suggest going the scale chassis route like the l-trail or the sac racing chassis. I think rcbro's was working on one but not sure if he ever finished it. you can build your own links like soudcolor said to get your wheel base and a scale chassis will let you do that easier. you can find the scale chassis links in the sticky for the MRC good luck and post your progress.
08-12-2009, 09:39 PM | #5 |
Rock Stacker Join Date: Jan 2009 Location: Spokane
Where did you buy that New Bright from?
