08-23-2009, 02:40 PM | #1 |
Rock Stacker Join Date: May 2009 Location: SoCal
| Modding to perfection
With everyone's opinion on the MRC and the mods out there...if you were to list your "perfect" mrc what would it be? No limit to what it is, the most simple or complex (price) but to you what would be your "dream build" parts list?
08-23-2009, 03:36 PM | #2 |
Rock Crawler Join Date: Mar 2009 Location: Cottontown
Mine is nearing what I would call perfection now Here is my current setup miXer chassis triangulated full delrin 4 link Hitec 645 servo alum servo arm striaght link sterring mod custom servo link split battery pack stock electronics mini slider motor (stock spur) dual heatsinks axial 8 hole beadlocks 7.5oz weight in each front wheel, 0 in rear Proline flat irons filed down front stubshafts, clearanced knuckles RcBros comp shocks (full droop, no springs) 70wt oil losi metal lockers F/C/R bolted axle housings What I would want, and will do eventually Tekin B1R CC BEC Punisher driveshafts Proline Chisels secondary battery pack alum. 1 piece rear axle C's Alum. front knuckles Front CV axles I may go lipo... I dont know |
08-23-2009, 05:11 PM | #3 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
MIne is the same as soundcolors only i have maximizer beadlocks not axial. Its about half way done still gotta order the servo, miXer kit, and the RcBros comp shocks. I am allredy done with the free/homemade mods. And i would change from flat irons to something a little smaller blue claws maby.... or chisels |
08-23-2009, 08:04 PM | #4 |
RCC Addict Join Date: Apr 2008 Location: Old Hickory
My set up Kamikaze mini Zero chassis hitech 645 axial rims chisels sidewinder Micro max amps lipo Futaba 3pm 2.4 wish list tekin fxr holmes hobbies motor or motormans not sure better smaller lipo and several of bec dna rims complete set of blue claws, bashers ( too go with the chisels and FI's ) somebody to come out with HIGH STEER KNUCKLES all the aluminum goodies with money as no object a mongoose set up would be nice |
08-24-2009, 02:29 PM | #5 |
Rock Crawler Join Date: May 2009 Location: Calgary
The mongoose rocks.......if you can afford it put it in. |
08-26-2009, 09:20 PM | #6 |
No more "wish list" builds?
08-26-2009, 09:47 PM | #7 |
New Toys. Got a killer deal on a new CC Mamba Micro Pro with the 4200kv motor. couldnt pass it up. puttin it in now |
08-26-2009, 10:08 PM | #8 |
An axial but i dont want to jack threads. my mrc is done
08-28-2009, 10:20 AM | #9 |
Quarry Creeper Join Date: Oct 2008 Location: Crawlin' in NorCal!
| Pretty Damn happy with mine!
Here is what I am running: -Darksoul/Chino Chassis -tekin fxr/ mamba micro pro (prefer the tekin but the mamba is what will be staying in my rig; try to keep it all Castle Creations for simplicity) -sr3100 rx -dx3r -losi aluminum threaded shocks-semi droop -OTA steering (not hard to make and well worth it) -losi aluminum goodies -rear lock out (which to a 30ft tumble and still held up!) -HH mini torque master (want to try out Poulsons though) -Chisels -Losi aluminum wheels/ Proline Titus wheels -Hitec 5995tg (overkill but I stole it from my bro) -CC BEC -Losi wide wheel hex's -MIP drivelines (A must!!!!) -Losi diff/cntr lockers (Tried the aluminum ones and didn't care for them) -Deans Plugs -Lipo's (I run the losi 1000, Hyperion 3rd Gen 800, and eflite 800; Hyperion by far the best one so far) -Bug body (not the prettiest thing but hell if I will ever get roll over points) Well that's about it and I am about out of ideas to go any farther with this one. I am now working on my daughter rig and she will probably be getting the mixer chassis so we will see how that one turns out. |
11-20-2009, 05:46 PM | #10 |
Rock Crawler Join Date: Mar 2009 Location: Frisco, Texas
well i got some mods and upgrade heres some of my mods: chassis plate chunked painted steering links roated the trans rotated the rear tires heres a list of UPGRADES : rcbros skulz adustable TVP'S REALLY angled shocks lowered 1 cm due to shocks integy roll cage roll cage cushions metal lockers in rear only and thats all, rest is stock, soon to be a TEKIN crawler wish list: tekin fxr spektrum reciever better motor (moongoose maybe) DNA 1.9 sniper beadlocks metal lockers all around metal skid plate and finially maybe bent links, but i LOVE the stock ones, they dont let rocks rub your shafts which is AWESOME Last edited by shadowrejects; 11-20-2009 at 05:49 PM. |
11-20-2009, 08:04 PM | #11 |
Rock Stacker Join Date: Oct 2009 Location: DesMoines
I just wish you could type in a truck body of any type or year, and it would be available as a lexan or hardbody scaley ! 61-66 ford f100 (slick60)
11-20-2009, 09:57 PM | #12 |
Rock Crawler Join Date: Jun 2009 Location: SF
I'm almost at what I think is perfect.. -Vanquish wheels with brass weights I made on the lathe (on the clock) full fronts, 3 each rear...claws...seacret foam -Mongoose 13th pinion -mini rockshow chassis/custom links (4 link) -Airtronics rock crusher -stock rx -Airtronics M-11 with spektrum module -aluminum f/c/r lockers -losi cvd's -aluminum knuckles front and rear, alum c's -losi alum shocks, limited 1/4" rear 3/8" fr 40wt oil 60wt left rear This thing does some things my bergs can't do!!! |
11-21-2009, 07:37 PM | #13 |
Pebble Pounder Join Date: Sep 2009 Location: Alabama
