08-25-2009, 08:33 PM | #1 |
Rock Stacker Join Date: Jul 2009 Location: freetown/newbedford
| tans swap
hey guys i just recently switched the tranny around to make more room for electronics i was just wondering if it does anything diffrent and i noticed when i spun it around reverse was forwerd and forwerd was reverse so i flicked the switch on the remout to make it right i was just wondering if that was the right way or if i was suposed to switch the wires on the motor or somthing like that and it seems to roll forwerd now down hill and when i let of the gas and in reverse it just slows down quick and stops ? just wondering if everything is ok ?
08-25-2009, 08:35 PM | #2 |
You can either change the polarity at your Tx or on your motor. Either method will work...
08-25-2009, 09:59 PM | #3 |
Rock Crawler Join Date: Mar 2009 Location: Cottontown
Either switch the radio (which you did) or the wires on the motor. Either way is fine, both do the same thing The stock motor is set to 0 degress timing, so it shouldn't act any diffrent in running either way |
