09-06-2009, 11:28 PM | #1 |
Rock Crawler Join Date: Jul 2008 Location: River Falls
| HR shock size vs. stock
Are the stock springs the same length as the Hot Racing ones? I need the soft set for my HR ones, and just want to be sure they're compatible before ordering..thanx! |
09-07-2009, 10:06 AM | #2 |
Pebble Pounder Join Date: Dec 2008 Location: Eastern, Oregon
Yes the springs are the same, you can mix and match. Another handy tip is to use the spring cups off the stock shocks. The shaft on the HRs are a little bigger so the stock cup will actaully snap on and not fall off at all. Just try it you will see the difference.
09-07-2009, 02:57 PM | #3 |
Thanx, man!
