10-09-2009, 05:22 PM | #1 |
Rock Stacker Join Date: Nov 2008 Location: Bismarck
| Front tires spin but rear dont
I broke a front drive shaft put on the mips, and now the rear wont spin with pressure on it, will spin if you hold it and give it throttle is this the center locker? It has both axles with metal locker so it shouldn't be that.
10-09-2009, 06:29 PM | #2 |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
Yes! I was the first of the lockers to go in mine.
10-09-2009, 06:42 PM | #3 |
Pebble Pounder Join Date: Nov 2008 Location: roseville
i would start with the center making sure no bolts came lose and nothing is damaged, then move to the outer diffs once again double checking everthing
10-09-2009, 06:46 PM | #4 |
Pebble Pounder Join Date: Sep 2008 Location: Anniston
gotta love those stock plastic parts! you my friend stripped your center locker!
10-10-2009, 05:47 AM | #5 |
Rock Crawler Join Date: Mar 2009 Location: Cottontown
Also, double check your set screws that hold your driveshaft onto the tranny's output shaft. if its not tight, it wont work right
10-10-2009, 07:10 PM | #6 |
Will tear it apart tommorow to check it out. I have to install the rear mip driveshaft yet, broke the front one got that on but haven't had enough time yet. Thanks for the advice.
10-11-2009, 08:51 AM | #7 |
Yep it was the center locker thanks again for the info.
