10-20-2009, 10:58 AM | #1 |
Newbie Join Date: Oct 2009 Location: Germany
| Lost Pin from Drive Shaft
Hi there! Sorry, but i have a problem with my new Mini Crawler. :( I lost the smallest pin of the Drive Shaft. Is there no way to buy only this pin? All i find is http://cgi.ebay.de/Antriebswellen-Mi...item3ca53aaa65 but i dont really need the whole set. Is there an improved version of it? I dont want to replace it all day long. Thanks alot Dom |
10-20-2009, 11:32 AM | #2 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
either buy another set or get mip or punisher driveshafts. thats really all you can do
10-20-2009, 12:02 PM | #3 |
Rock Crawler Join Date: Jan 2006 Location: SUPERMOTO heaven
a traxxas body pin fits just about perfect. Just cut to fit and make sure you squash the ends with some pliers to help it stay in place.
10-20-2009, 12:56 PM | #4 |
Rock Crawler Join Date: May 2009 Location: 354
| shaft
just get a small nail that would fit and then bend both ends so it would'nt come off anymore, just make sure that when you bend it, bend it flush so that it doesnt get in the way when you're crawling, permanent fix, i did this on my mrc it works great for a few months now and yes i bash the living daylights out of this thing, mud and all |
10-20-2009, 02:13 PM | #5 |
Pebble Pounder Join Date: Sep 2009 Location: The Land of Ahhhhs
Buy a drill bit that size, cut to fit, brad (rivet) the ends just a little, then put some electrical shrink tube over that area. |
10-20-2009, 06:43 PM | #6 |
Pebble Pounder Join Date: Sep 2008 Location: Anniston
happened to me and here were the responses I got.. missing D-shaft pin... Last edited by crawlinlosi; 10-20-2009 at 06:46 PM. Reason: corrected content |
10-22-2009, 04:16 PM | #7 |
Quarry Creeper Join Date: Aug 2009 Location: here
I read somewhere about someone soldering in their pins. Maybe find some copper wire in the right diameter and solder it in to keep it in place.
10-22-2009, 04:41 PM | #8 |
Rock Crawler Join Date: Mar 2009 Location: Cottontown
Stick a metal non coated body pin in it, and then bend the end of it around the shaft so it wont come out. Easy and cheap |
10-22-2009, 04:59 PM | #9 |
Quarry Creeper Join Date: Mar 2009 Location: mesa
here's the ticket use traxxas#1539 you need two of these and one of a traxxas#1951 you will have to cut down the half shafts to fit your length my mini eats the stock shafts for breakfast thanks to a brushless motor so far these have stood up to full throttle launches up the rocks where the stock shafts would have snapped i tried integy shafts but i snapped them too five sets of stock ones they only last two comps per set in arizona the traxxas parts cost me 16.00 and a hour of my time i think its the only way to go now in my opinion
11-10-2009, 09:31 PM | #10 |
Rock Crawler Join Date: Mar 2009 Location: Frisco, Texas
| i heard paperclips work, but their easy to bend |
11-10-2009, 10:09 PM | #11 |
Rock Stacker Join Date: Oct 2009 Location: DesMoines
We have just used some small piano wire, we bend it on one end before installing, then the second one after sliding it on.
11-11-2009, 06:58 AM | #12 |
RCC Addict Join Date: Feb 2008 Location: your back yard
Anything small enough to fit will work. I ended up using body clips. So far no issues and was an easy fix..
11-11-2009, 01:07 PM | #13 |
Newbie Join Date: Oct 2009 Location: North River
I just used an old body clip, cut it size and soldered it at both ends then put shrink tube over it and its worked great ever since!
11-13-2009, 07:57 PM | #14 |
Newbie Join Date: Nov 2009 Location: Denver
same thing happened to me. DO NOT buy intigy drive shafts!!!! 30 dollars poorly spent! those DS's broke in a hurry!
