12-20-2009, 08:55 PM | #1 |
Newbie Join Date: Dec 2008 Location: Mukilteo
| rx-280 question
After doing lots of reading on here I have installed a rx-280 motor with a 12t pinion. the problem i am having is that when i first start to run it, it has no power and dosen't move very fast and if you put it in even the slights bind like trying to crawl something it shuts the speed control down and i get the red flashing light for 10 to 20 seconds then it starts back up. Then after i drive it around for a little the motor seems to then wake up and run like it should, lots of wheel speed and good torque. I have doubled checked the gear mesh and i make sure the battery is fully charged. The only reason i changed the motor is the stock one was getting tired. I am running all stock electronic and battery. Thanks in advance |
12-20-2009, 09:00 PM | #2 |
Rock Stacker Join Date: Dec 2009 Location: salt lake
is the speed controller and motor brand new? and how old is our battery? |
12-20-2009, 09:18 PM | #3 |
the speed control and the battery is about a year the motor brand new
12-21-2009, 09:12 PM | #4 |
do you have any more cars you check your battery in?
12-23-2009, 09:12 AM | #5 |
Rock Stacker Join Date: Sep 2008 Location: Reno
I am having the same issue. I replaced the stock motor only after it died with the RX-280. Motor runs great as long as you don't get in a bind. When it stops it is like I lost all power (No steering too). When I pick it up it all comes back. The ESC doesn't feel hot and it is not very old but the motor does get warm. I would like to figure it out before my Mongoose system get here. I just like to know why it happens.
12-14-2011, 05:19 AM | #6 |
Rock Crawler Join Date: May 2011 Location: at your moms
i just put a rx-280 in my project mini last night, mine seemed to be running fine, crawling or at speed. my mrc is completey stock and brand new, i will bind it up tight to night to see if i can duplicate issue Ron
12-14-2011, 05:42 AM | #7 |
I wanna be Dave Join Date: Mar 2009 Location: SW Missouri
I stuck an rx-280 in my daughter's rig. It has lots of wheel speed and torque, no problems so far. The only thing I've noticed is it's a bit noisy and seems to drain the battery faster than expected. It's on a Castle ESC, so that may be the difference, sounds like the stock ESC can't handle the load.
12-16-2011, 06:58 PM | #8 |
Quarry Creeper Join Date: Nov 2010 Location: mandan
| Re: rx-280 question
I was having the same issue found out that when I ran a higher dump battery it stopped. was running 20c, now running a 65c hope this helps
12-16-2011, 07:20 PM | #9 | |
| Re: rx-280 question Quote:
Our MRC packs are 2S 325mah(?) 65C packs from CBP. | |
12-23-2011, 04:46 AM | #10 |
| Re: rx-280 question
ive run mine through several packs and have no issues with it yet, im running 1000mahs with 20c Ron
12-24-2011, 10:03 AM | #11 |
| Re: rx-280 question
i run mine last night pretty hard, it didnt shut off but the motor got very hot, im going to install a different pinion and try it some more Ron
01-01-2012, 12:17 PM | #12 |
Newbie Join Date: Dec 2008 Location: A-town
| Re: rx-280 question
Installed mine yesterday with an 11t pinion and I got the same results as the op after charging my battery pack overnight. Mine doesn't even feel that torquey at all either, of course I've got flatirons on it though. At this point the stock mrc motor was way better. Looks like I'm looking for another motor again. Kevo |
01-01-2012, 12:24 PM | #13 |
Rock Crawler Join Date: Jul 2008 Location: River Falls
| Re: rx-280 question I've got flatirons on mine too. Running a 10/62 set-up with a losi Insane motor. Tons of torque, tons of wheelspeed...
