Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Mini-Rock Crawler
Thread: Mini Wide Ride kit - anyone using?
Old 12-04-2009, 11:44 AM   #1
Ipe
Default Mini Wide Ride kit - anyone using?
Hey folks, I'm looking for some wideners for my sons MRC and my LHS guy can't get the GMade. He can get the Mini Wide Ride kit from Horizon. They bump the width out by a two inches, vs. the 1.5 of the GMades. Are any of you guys using this kit? Any thoughts?
Thanks in advance,
Ipe
Ipe is offline   Reply With Quote
Old 12-04-2009, 11:52 AM   #2
20K Club
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
I ran wideners on mine for awhile, however I would not put them back on.
Harley is offline   Reply With Quote
Old 12-04-2009, 12:12 PM   #3
I use the Traxxas ones myself (2 ea. Traxxas #3654 Wheel Hex). I wouldn't go too wide or you're gonna start breakin' stuff.
Biggons is offline   Reply With Quote
Old 12-04-2009, 12:16 PM   #4
www.esphobby.com has a widening kit and long arm kit
A DOG is offline   Reply With Quote
Old 12-04-2009, 01:57 PM   #5
The huge scrub radius disgusts me.
ToyTundra is offline   Reply With Quote
Old 12-04-2009, 02:12 PM   #6
20K Club
Harley's Avatar
Yup, huge waste.
Old 12-04-2009, 03:17 PM   #7
Ipe
That pretty much confirms it for me. I'm going to pass on these. Its just too wide. Thanks for the feedback.
Old 12-04-2009, 07:00 PM   #8
How much wider are the Traxxas spacers and how do they fit the axle?
stubs179 is offline   Reply With Quote
Old 12-05-2009, 02:52 PM   #9
the traxxas hexes will widen the track width about 1/4" overall.
taken from
http://www.rccrawler.com/forum/showt...80#post1519780
.... I didn't like the way they fit on my MRC. Because of the larger drive pin used with these hubs, when i put the wheel on, the traxxas hubs rubbed against the outer axle bearing. I drilled out the drive pin hole to fit the 2mm traxxas pins. No more rubbing and the hubs didn't come off with the wheel. After that, i didn't like the loose fit of the hub to the axle. To solve this, i cut some short pieces of 3/16" brass tubing. Maybe it is overkill, but it works for me.
HTH
rex cars is offline   Reply With Quote
Old 08-03-2011, 10:55 AM   #10
Originally Posted by Harley View Post
Yup, huge waste.
nice way to kill a servo
mhflies is offline   Reply With Quote
Old 08-03-2011, 11:04 AM   #11
Location: Turn the mayflower around.. it will never work
meh.... toss out the micro and bump the voltage to 8 volts.... no problem
JokersWild is offline   Reply With Quote
Old 08-04-2011, 06:14 PM   #12
http://i.pgu.me/3Acg3tCO_original.jpg
There's pic comparison of wideners in link on front of my brothers rig next to mine without. Adds about a tire width overall. As you can see
http://store.rc4wd.com/Mini-12mm-Whe...r-4_p_273.html
Whop is offline   Reply With Quote
