01-07-2010, 07:41 AM | #1 |
Rock Stacker Join Date: Jan 2009 Location: Stockton, CA
| MRC Servos....
I know most guys go for the larger, high torque servos w/ their MRC, but I was wondering if the below "Mini" sized servo would work for my next application, because when I strip the Losi servos again, I don't want to rebuild them - serious pain! Would this mini metal gear servo work as a Drop In fit? I want to stay w/ the same size of servo as stock, as I am running the Losi LiPo battery on my front axle, and have no desire to chase down custom servo mounts, either. If anyone has any feedback, I would truly appreciate it - thanks! http://www.helidirect.com/hitec-hs22...sal-p-2305.hdx |
01-07-2010, 07:58 AM | #2 |
Quarry Creeper Join Date: Nov 2009 Location: San DIego
I had bought a hit ec mini metal gear servo, and in 2 days it burnt out, but thats with no servo saver on it. I put in the losi, no saver and it died the same day. So I upgraded to a full size, but also bought a new radio with endpoint adjustments and im still using the same full size hitec servo for 2 weeks now. I would suggest swapping the radio out to one with the endpoint adjustments, its your best bet to saving the servo if your upgrading it. My dad still runs the stock, with saver and losi radio for 2 months now.
01-07-2010, 09:51 AM | #3 | |
Right now, I'm good, but if I strip a servo, I'll have to dig up some threads and try to find a better option. Thanks! | |
01-07-2010, 09:58 AM | #4 | |
Funny you say that, I use the losi lipo and full size servo on the carbon plate. I made my own steering linkage from solid aluminum from home depot, and used threaded pieces that can be bought online or from leftover lower bent links for the mrc. All you have to do is move the inner servo mount over a hair, redrill the holes in the plate and you can mount a full size servo, with a little filing on the mount hole if needed. Really didnt cost me anything except a few $ for the rod. | |
01-07-2010, 03:04 PM | #5 |
Quarry Creeper Join Date: Dec 2009 Location: Jacksonville, FL
The Hitec 5245MG is still a mini but has more torque than the 225MG. The 225MG isn't much more torque than stock.
01-07-2010, 03:07 PM | #6 | |
God bless - "Rare" | |
01-07-2010, 03:50 PM | #7 |
Newbie Join Date: Sep 2009 Location: Marietta
I went with a HiTec HS-225 mgand it is the same size as stock. It has worked with different tires and added beadlocks and weighted wheels and it has handled the last 2 trips out on the rocks well.
01-07-2010, 05:00 PM | #8 |
01-07-2010, 05:19 PM | #9 |
I had to change how it connected to the linkage using some piece (sorry dont know all the names) but the servo did screw into stock place. |
01-08-2010, 12:27 PM | #10 |
Pebble Pounder Join Date: Dec 2008 Location: Eastern, Oregon
Get this servo and dont look back forget about the Hi tech stuff http://www.allerc.com/product_info.p...oducts_id=3974 This servo has been simply great to me been running it for a year and half in a comp MRC and I have not been nice to it. The only thing is it has 1 plastic gear that they call a fuse to protect the elecs. in the servo get a package of these replacement gears from the same site they are $2.80 for 4 or 5 of them. Oh and I have only had to replace it once myself and I dont have epa's on my tx. Make sure you get HP-DS16FMD not FCD.
01-08-2010, 02:44 PM | #11 |
01-08-2010, 03:21 PM | #12 |
Rock Crawler Join Date: Dec 2008 Location: With the ATL Crawlers
If your wanting a "direct drop in" then choose a decent digital mini servo. Most are the same dimesions as stock. You've got the right radio for the job. From my past experience, I've burnt up a 5245 the very first time I used it. It's still a great servo if end points are used. Just if you stay w/ mini servo's, watch bind situations and keep it light. My .02
01-08-2010, 03:23 PM | #13 | |
Thanks!!! | |
02-08-2010, 11:42 AM | #14 |
Newbie Join Date: Jun 2009 Location: UK
I also just bought a 5245 and it seems to have burnt out within 3 hours use think its time to upgrade to a full size servo |
02-08-2010, 01:27 PM | #15 |
Rock Crawler Join Date: Aug 2009 Location: crawlerado springs
just go with the hitec 645. i used the stock mounts... i just had to get the mounting plate! which you can easily make. my mrc is sittin at about 10 to 15 pounds and the 645 isnt even phased by the weight! i think it would be better to buy the 645 and a plate than have to buy servos over and over because they burn out! thats just my 2 cents. |
02-08-2010, 02:12 PM | #16 |
Pebble Pounder Join Date: Feb 2005 Location: Chandler, AZ
You guys must be really hard on your servos. I ran a HS-5245MG for months with no problems. A few weeks after i added flatirons the motor burned out though. A fullsize is cheaper and stronger.
02-08-2010, 02:20 PM | #17 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
I use a hitec 7955 on miine. It works like a champ. A little overkill but hey I had it sitting there so why not use it. A 645 or a 5645 would be plenty though.
02-09-2010, 05:26 AM | #18 |
| even if i was being hard on it i would expect it to last longer than 3 hours though?? |
02-09-2010, 11:56 AM | #19 | |
TN State Champ 11,12,13 Join Date: Oct 2008 Location: KTM Talk.com
I'm surprised that mrc will even move at that weight. How is it even possible to be that heavy:? A super shouldn't even weigh that much! You seriously need to put that truck on a diet if it really weighs that much. Last edited by Pdog7; 02-09-2010 at 12:00 PM. | |
02-09-2010, 12:56 PM | #20 | |
