01-09-2010, 12:17 PM | #1 |
Rock Stacker Join Date: Mar 2004
| Drive shaft help..
I was installing my MIP cvds and when i went to take the last set screw out of the drive shaft on the axle it stripped out. I tried to cut a slot in it and take it out with a screw driver but it just to small. Any ideas on how to get this thing out? And also recommendations on a good set of allen wrenches?
01-09-2010, 12:23 PM | #2 |
Quarry Creeper Join Date: Jul 2006 Location: In a tree top with my chainsaw!!
I had the same prob when replacing my stock driveshafts. I tried to drill it out with no luck. I ended up cuting it off with my dremel. Lucky I was replacing it.
01-09-2010, 02:00 PM | #3 |
Newbie Join Date: Nov 2009 Location: Phoenix
Try heating it up a little and also tapping the screw driver or allan wrench onto the screw to get a tighter fit. Good luck.
01-09-2010, 02:51 PM | #4 |
Quarry Creeper Join Date: Mar 2009 Location: mesa
if its a 1.5mm try a 1/16 or a 1/8 " allens i cant remember which one will fit the stripped metric screw
