01-12-2010, 10:09 PM | #1 |
Rock Stacker Join Date: Dec 2009 Location: Redmond
| GC3 Conversion Questions
My wife got me a MRC for Xmas and it is the best gift ever! After a few weeks and plenty of RCCrawler reading I have decided to give it a make over. I have decided on a GC3 Chassis but have some questions on what else I may want (I know all I need is a MRC and GC3 but am interested what else would be beneficial). So far I have on order... GC3 Chassis Losi Threaded Shocks (I was leaning towards Vendetta shocks but find them ugly) HiTec 645 Servo Flat Irons Dark Souls OMF Beadlock Rims 1. I've seen people talk about "lockers". What are lockers for? 2. Are shock bushings needed? 3. Do the Losi 30 deg clearance links provide a benefit with this chassis? 4. I've seen some clearance questions/issues from other build threads. Is there anything I should prep for in advance? |
01-12-2010, 10:42 PM | #2 |
Quarry Creeper Join Date: Aug 2009 Location: here
You'll definatly want the lockers, they are steel replacements for the plastic pieces that hold the axle shafts in the differential. With the taller tires you'll definatly need them. And you might as well install them while you have the MRC apart. Get two sets for the axles and the center locker for the trans. As for the bent links the kit looks like it rides pretty low so I don't think you'd need them, and the kit comes with new links so just run them for a while and if you feel you would benifit from them add them on later. As for the shocks I have the losi threaded and wish I would have bought some other shocks. Mine leak and one leaks bad on both ends. I only have two packs through them and am not too impressed. I used teflon tape on the cartrages and that helped some, next I'm going to use some on the caps to see if that will help. And you wont need bushings for them. The GC-3 uses the stock ball stud on the top of the shocks so you'll be good there. My GC-3 is in the mail right now and I can't wait till it sows up. Have fun with yours. |
01-13-2010, 01:34 AM | #3 |
You talked me out of the Losi shocks and I canceled my order and went with Vendettas |
01-13-2010, 05:45 AM | #4 |
Pebble Pounder Join Date: Feb 2009 Location: Long Island
after I got my vendetta shocks together and tested them out on my gc3, they are the best shocks I've tried to date. I'm running the white (soft) springs up front and the stock yellow in the rear and they work great for me. Im also running flatirons for now because I like the added clearance, but these tires are terrible on smoother or wet surfaces. I'm changing them out for some hb rovers. The gc3 is the best mod out there. This little guy is a beast now |
01-15-2010, 01:34 AM | #5 |
Another question... Mounting the electronics looks like it's going to be a tight fit. From the builds I have seen I havent seen anyone mount the receiver or esc over the rear axle. Both are pretty light so I'm wondering why people avoid doing this?
01-15-2010, 06:40 AM | #6 |
| Some people like a front weight bias.
01-15-2010, 07:58 AM | #7 | |
Quarry Creeper Join Date: Apr 2009 Location: Lillington, NC
Cole | |
01-15-2010, 06:53 PM | #8 |
Newbie Join Date: Nov 2009 Location: Canada..Eh?
I got my MRC with the free Lipo and plate on. I used mounting tape and taped the Carbon Fibre plate on my aluminum one that came with the GC3, and put the servo and battery on that. My question, I had the toruble of the upper links hitting my shocks, do the Vendetta shocks hit? |
01-15-2010, 07:10 PM | #9 | |
Quarry Creeper Join Date: Dec 2009 Location: Jacksonville, FL
01-15-2010, 10:17 PM | #10 |
| Could you post a close up pic of that set up?
01-15-2010, 11:59 PM | #11 | |
I thought of that after I put the tape on :l Now I can't get the darn thing off! | |
01-16-2010, 07:50 AM | #12 |
01-16-2010, 11:11 AM | #13 |
01-16-2010, 02:57 PM | #14 |
Nice! I'm not sure I can use it with a full size servo but will try and see if it works.
01-16-2010, 06:53 PM | #15 |
@ MRCNoob. Are those pen springs? I did the same thing you did, but after a few runs my pen springs are starting to soften :l And is that a MRC lower link as your steering link? |
01-16-2010, 08:29 PM | #16 | |
They're not pen springs they are the TCS internal springs that I cut to the length I wanted. Regular springs on this chassis hit the 4 link bars, at least the way I have my shocks mounted. Yes that is a MRC lower link and rod ends. | |
01-16-2010, 09:02 PM | #17 |
Rock Stacker Join Date: Nov 2009 Location: pueblo (P-Town)
How did u get the lower link to fit as ur. Steering link ????
01-16-2010, 09:23 PM | #18 |
| The rod ends just aren't threaded all the way down. But it is attached just like the stock link. It's actually kind of nice since my stock link gave me a little toe in, with this link I can adjust toe. |
01-16-2010, 09:33 PM | #19 |
Newbie Join Date: Oct 2009 Location: milford
| if you move your upper links to the inside of the chassis you can gain some more clearance
01-17-2010, 07:09 AM | #20 |
