01-16-2010, 05:37 PM | #1 |
Pebble Pounder Join Date: Jan 2010 Location: CA
| Who has burned out the stock motor by flipping the tranny?
I can't seem to get a straight answer on the stock motor timing. I am curious to hear how the stock motor is holding up when running in reverse on a flipped tranny. I would like to hear from the people that has done this mod and ran the heck out of there stock motor being reversed. Thanks
01-16-2010, 05:48 PM | #2 |
Quarry Creeper Join Date: Aug 2009 Location: Acushnet Mass near cape cod
Tons of people flipped the motor\trans and I have not herd of any problems . Mine has been running set to rev throttle for a long time . Has been good so far |
01-16-2010, 06:09 PM | #3 |
Pebble Pounder Join Date: Sep 2009 Location: Alabama
It is set at 0 degrees. It does not matter if your tranny is forward or backwards. You could check the OTHER thread too.
01-16-2010, 07:47 PM | #4 |
Rock Crawler Join Date: Mar 2009 Location: Cottontown
Negative ghost rider, the stock motor is running advanced... However, its not a problem... you'll never run it long enough, or fast enough to matter |
01-16-2010, 08:20 PM | #5 |
Really? I guess that makes since though. I always adjust my esc to it, thats probably why. I don't have any trouble running my tranny reversed though.
01-16-2010, 08:30 PM | #6 |
Rock Crawler Join Date: Sep 2008 Location: Salem,Oregon
never played with motor timing if you are looking at the bell do you turn it right or left to advance the timing
01-17-2010, 05:53 AM | #7 |
The stock motor is not adjustable. Without modifying the can you can't turn it either direction |
01-18-2010, 12:39 AM | #8 |
Rock Stacker Join Date: Jan 2010 Location: Dallas
01-18-2010, 01:51 PM | #9 |
if you plug the red motor wire to the black esc wire and the black motor wire to the red ecs wire, you dont have to run anything reversed, mines been like that for 2 years and its fine
01-18-2010, 04:40 PM | #10 | |
I wanna be Dave Join Date: Oct 2008 Location: I miss Rowdy
ANCICHF: Just go away, your credibility on this site is gone. You are not wanted, and your wisdom is not needed. You are an idiot, a liar, and a scammer. When will you get the hint. | |
02-09-2010, 04:52 PM | #11 |
RCC Addict Join Date: Sep 2007 Location: Westland, MI
