01-17-2010, 03:45 PM | #1 |
Rock Stacker Join Date: Mar 2004
| 4 link.
Im thinking of doing a four link set up and would like to see pics of your set up? What ends did you use? How did you attach it to the axle?
01-17-2010, 04:13 PM | #2 |
Rock Crawler Join Date: Mar 2009 Location: Cottontown
Here's a tip kiddo, Use the search button, |
01-17-2010, 04:58 PM | #3 |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
It is really easy...............Buy a GC3! |
01-18-2010, 08:22 AM | #4 |
Quarry Creeper Join Date: Nov 2009 Location: San DIego
Here are some pics of mine, I used stock length lower suspension bars at first, then made my own. The rear mount is in the same place as the front and I used ball ends to mount everything, losi ones. Also here is a video of 3 link and 4 link you can really see the difference as there is no wheel lift at all. If you look for my newest mrc video it shows a super steep climb. http://www.youtube.com/watch?v=TwniNn4OuVU |
01-18-2010, 09:16 AM | #5 |
01-18-2010, 09:28 AM | #6 |
01-18-2010, 09:31 AM | #7 |
I did the same setup on my dads mrc which was using the stock chassis if that helps. I just used my extra lower suspension bars on his.
01-18-2010, 10:28 AM | #8 |
Newbie Join Date: Apr 2009 Location: Auburn
Get the rc bros plates and make your links
01-18-2010, 08:40 PM | #9 |
No pic yet. Im using stock plates.
01-18-2010, 08:54 PM | #10 |
Quarry Creeper Join Date: Apr 2009 Location: Lillington, NC
01-19-2010, 01:39 PM | #11 |
Pebble Pounder Join Date: Feb 2005 Location: Chandler, AZ
Rear: Front: both use 1/8" brass tube, some 4-40 allthread and stock MRC rod ends. |
01-19-2010, 08:58 PM | #12 |
01-19-2010, 11:56 PM | #13 |
Quarry Creeper Join Date: Aug 2009 Location: here
I must give you mad props for your front link mounts. I was trying for a while to figure out a way to mount them besides onto the servo plate and couldn't. You came up with a simple and very good idea.
01-20-2010, 04:38 PM | #14 |
| thanks. I need to tweak it for more vertical spacing between the links, then it will be perfect. I was too focused on getting the servo low so I compromised the suspension geometry.
01-27-2010, 11:45 AM | #15 |
Newbie Join Date: Aug 2005 Location: phoenix
Im gathering the parts to 4 link my MRC, first the rear and eventually the front. Will this help w/ TT?? |
01-27-2010, 12:49 PM | #16 |
RCC Addict Join Date: Oct 2007 Location: Kennewick, Washington
01-27-2010, 01:35 PM | #17 |
Rock Crawler Join Date: Aug 2005 Location: Illinois
Or just buy a GC3 |
01-27-2010, 02:02 PM | #18 |
02-20-2010, 12:33 PM | #19 |
Newbie Join Date: Nov 2008 Location: Germany
02-20-2010, 01:42 PM | #20 |
Rock Crawler Join Date: Mar 2009 Location: Frisco, Texas
you know if you got the bent links you could use the old links and attach them to the old y arm locations and run them down to the rear servo plate and attach them into the 2 screw holes its a homemade 4 link mod! |
