01-18-2010, 02:41 PM | #1 |
Rock Stacker Join Date: Jan 2010 Location: Greer
| new problem!!!!!
when i turn my crawler on it wont do nothing at all the speed control light will blink sometimes but the reciever light wont come on.all of the wires are connected,i thank it might be the reciever.i flipped it over in a puddel yesterday and this morning nothing is working.
01-18-2010, 02:52 PM | #2 |
When you flipped it in the puddle, did the ESC get wet?
01-18-2010, 02:54 PM | #3 |
im pretty sure it didnt but it could have.half inch puddel and flipped it on its side
01-18-2010, 02:56 PM | #4 |
Hummm....you might check the ESC and make sure that it has not gotten wet. BTW, what do you mean "all of the wires are not connected"?? Which wires? |
01-18-2010, 02:59 PM | #5 |
i mean connected sorry about that ill edit it and ok
01-18-2010, 03:05 PM | #6 |
Ahh...ok. Well, if everything is properly connected and you havent made any changes lately, then you should, at the very least, have servo control. I'd guess that either your Rx or ESC is wet. Pop the cases open and let them dry...
01-18-2010, 03:12 PM | #7 |
ok thanks for the help
01-18-2010, 05:17 PM | #8 |
Quarry Creeper Join Date: May 2008 Location: Lafayette, Indiana
did you try rebinding? maybe it became unbound for some reason?
01-18-2010, 05:44 PM | #9 |
Newbie Join Date: Sep 2009 Location: Marietta
01-18-2010, 05:59 PM | #10 |
thanks rebind was the answer thanks man
01-18-2010, 06:08 PM | #11 |
Glad you got it figured out. That is strange....I have quite a few Spektrum Rxs on different vehicles and I've never had to rebind them unless I changed something on the radio...
01-18-2010, 06:49 PM | #12 |
lol. start simple |
01-18-2010, 09:50 PM | #13 |
Quarry Creeper Join Date: Aug 2009 Location: here
I know you got it fixed but if sombody else has a problem and comes across this thread. I just had a problem where I couldn't get mine to turn on, here the wires both broke off for the switch on the esc. I ended up bypassing the switch for now until I get a hold of some nice wire and a better switch. Losi uses some cheap stiff wires.
01-18-2010, 10:20 PM | #14 |
Newbie Join Date: Nov 2009 Location: north san diego county
I had the problem with mine. Losi is sending me new parts since I only got to run it for a few minutes. I think it was the reciever because the ESC light remains on, but the receiver doesn't light up at all.
01-18-2010, 10:35 PM | #15 |
Pebble Pounder Join Date: Jan 2010 Location: Gluing my mirrors back on!
If you have to keep re-binding, start by changing the Tx batteries for sure. The AAs that came with my kit croaked after just a few minutes. The ESC light came on, but the Rx LED just flickered dimly when this happened, BTW. No more trouble after replacing the batteries!
01-19-2010, 08:26 AM | #16 |
yeah the wires are not to good.they come off to easy,ill roll mine over sometimes and it will cut off then cut right back on.
01-19-2010, 08:28 AM | #17 |
ha yeah i thank thats one of the frst thing i should have checked ha
