01-19-2010, 08:06 PM | #1 |
Rock Stacker Join Date: Nov 2009 Location: pueblo (P-Town)
| pro line rims and tires
I just picked up a pair of pro-line beadlocks and pro-line flat irons haven't taken them out yet just woundering what other peeps think bout the flat-irons and the pro-line beadlocks. I like the bead locks but I didn't no the acuttal rim was plastic I hope they hold up? I'm thinking bout gettinng the chissels but idk yet any thoughts ????
01-19-2010, 08:35 PM | #2 |
Rock Crawler Join Date: Aug 2009 Location: crawlerado springs
i really like my flatirons, how ever i did chop off every other lug of tread! they work great!
01-19-2010, 08:52 PM | #3 |
Rock Crawler Join Date: Mar 2009 Location: Cottontown
After a lot of abuse, I can firmly say.... the rims will take a beating. Mine are finally starting to wear out in the hexes... As for the flat irons, cut every other lug off, (search for the butchered flat iron thread), and add about 6 oz in the front, and none in the rear. Then use the stock proline memory foams up front, and round up a set of stock axial 2.2 foams cut down for width in the rear and the are great. I would cut every other row of lugs off the rear tho... Read the thread and you'll understand the principle |
01-20-2010, 01:29 AM | #4 |
Newbie Join Date: Jan 2010 Location: washington
I have flat irons as well and have no complaints
01-20-2010, 04:26 AM | #5 |
Newbie Join Date: Dec 2009 Location: Terrace
| I just got my rims and proline flat irons today... install was easy and they work 100 times better than stock
01-20-2010, 05:11 AM | #6 |
RCC Addict Join Date: Apr 2008 Location: Old Hickory
I'm currently running the Dark Soul rims on my MRC but I have plans to use those on a HONCO I'm hopeing my lovely wife gets me for my birth day. I plan to get the proline beadlocks for my MRC when that happens. As Far As tires go I think the chisels and flat irons are great tires it really depends on the terrian your crawling on to decide which is the best of the two. I'm currently happy with the cobras and the more I read about the hot bodies rover 1.9's they might find a way to my bench |
01-20-2010, 08:08 AM | #7 | |
And these damn losi alum shocks leak like a stuck pig what can I do to stop this. | |
01-20-2010, 12:25 PM | #8 |
The theory for adding more weight up front is simple. The heavier something is, the harder it is to move. The lower the weight, the the more stable. Thus adding weight to the front. Now, as to how I add MT weight, well.... Lead heated on a pot until liquid, poured into a mold the width of the channel. Let cool, wrap and cut. Works best |
01-20-2010, 08:30 PM | #9 |
I had to eun a small aluminum wheel widener to run the flat irons and they also made my rig much more stable on side hilling.
