01-24-2010, 10:40 PM | #1 |
Pebble Pounder Join Date: Jan 2010 Location: CA
| GC3 upper links hitting on shock springs
I finished up my GC3 conversion and I am having a problem with the upper links on the four link hitting the shock springs. It then pushes the spring of the spring perch. I have the top of the shocks spaced out with a 3mm nut but it is still not enough. If I mount the links on the inside of the chassis, will it mess up the geometry? The upper links would be parallel and not have the triangle shape. I also tried taking the springs off but I need more ground clearance for the crawling that I do. Is there better spring perches that would keep the spring on better? I am still using stock shocks. Thanks
01-24-2010, 10:46 PM | #2 |
RCC Addict Join Date: Oct 2007 Location: Kennewick, Washington
What shocks are you running?
01-24-2010, 10:50 PM | #3 |
I am still running the stockers
01-24-2010, 11:27 PM | #4 |
Newbie Join Date: Oct 2009 Location: milford
i run my uppers mounted to the inside of the chassis on the lowest hole. the lower links end up hitting the rod end and limit articulation perfectly(for me) , but it also gets you the clearance you need for the shocks.
01-24-2010, 11:27 PM | #5 |
Quarry Creeper Join Date: Aug 2009 Location: here
Space the lower shocks out. Use M2x20mm screws and move the rod ends to the outside of the shock mounts.
01-25-2010, 08:53 PM | #6 |
RCC Addict Join Date: Feb 2007 Location: LRC
If you will put a 7/16 spacer inside your shocks to make them shorter the problem will go away,it will still hit the spring but it will not knock it off the perch.The best thing to do would be get the vendeta shocks they are the right height and they are very smooth and they will not leak shock oil everywhere like the losi ones .To get the 4 link dialed in that is where they had to be ,try limiting the shocks first and see how you like it
01-26-2010, 04:27 PM | #7 | |
Rock Stacker Join Date: Feb 2004 Location: Western WA
I tried mounting the upper links to the inside of the chassis, but that caused the driveshaft to contact the link hardware on compression. I've been needing to post my build thread for a week or so - I'll try to get to it tonight and include photos of how my shocks are setup. - Chris | |
01-26-2010, 08:42 PM | #8 | |
sounds like vendeta shocks are the way to go. | |
