01-25-2010, 10:26 AM | #1 |
Rock Stacker Join Date: Jan 2010 Location: wallingford
| First crawler
Hi I just bought a used mrc with these mods integy steering link and integy lower suspension links .. the rest is bone stock... I was wondering what mods would be the first to do? im on a limmited budget looking for the most bang for my buck .. to increase climbing performance .. I also have another question on charging the batterys .i have a reedy quazar my pro charger wondering that amps i should charge/discharge 1100-1600nimh at also what my peak adjust setting should be for exp.(5mv/c 30mv/p) .and what the trickle currant should be?? Looking forward to get into the crawling !!! thanks |
01-25-2010, 01:55 PM | #2 |
Newbie Join Date: Sep 2009 Location: Marietta
The first thing to do is get everything lower. Battery on the front/rear axle, move electronics to the links or axle. It took me awhile to play around with placement but I got everything lower now. Also I found weighting the front wheels helped a lot.
01-25-2010, 04:49 PM | #3 |
thanks what did you use on the upper link to mount the electronics ??
01-25-2010, 05:15 PM | #4 |
Rock Crawler Join Date: Sep 2008 Location: Nashua,NH
01-25-2010, 05:26 PM | #5 |
| if you have any pics of your budget mods can u post them ? also with the stock frame is anyone moving the shock mounting point pros/cons ?? Im hooked already on the crawling thing |
01-25-2010, 06:51 PM | #6 | |
I got real cheap (and light weight) and used double sided tape but it does work. As far as shock relocation, when I cut the battery tray out I just turned the remaining plastic up and it made the shocks higher which lowered the ride. | |
01-25-2010, 08:08 PM | #7 |
nice Ill look into that too
01-25-2010, 08:38 PM | #8 |
Rock Stacker Join Date: Jan 2010 Location: Greer
medal lockers the stock ones wont hold up long
01-26-2010, 04:59 AM | #9 |
Here is the only picture that shows what I was talking about. You can see the plastic I left after the first cut and all you do is turn it where the shock mount is up. After I turned them up I ran a long zip tie (not pictured) between them to keep their place. |
01-26-2010, 06:16 AM | #10 |
| good stuff here thanks
01-26-2010, 04:24 PM | #11 |
Newbie Join Date: Jan 2010 Location: Tacoma
| Thanks
Thanks bigbeave1. I am in the same place your are. Just got a new/used MRC and wanting to make it better.
01-27-2010, 04:04 PM | #12 |
Newbie Join Date: Jan 2010 Location: Redlands
get a lipo battery, and the mount. it will put the battery and steering servo next to each other, pretty well balanced!
01-27-2010, 05:12 PM | #13 |
anyone have any pics of the stock shocks setups my shocks have no clips and the there is a gap say 1/4 in when i hold the truck up is there supposed to be a gap there what mods can be done to the stock shocks im learning the terminology thanks .. Set up so far lower links, steering arms came that way 1.1/4 oz in all the wheels is there a classified section ?? i looking to buy some used stuff |
01-27-2010, 05:30 PM | #14 |
Newbie Join Date: Jan 2010 Location: Seattle
my lil' 1/18 showed up today,ordering metal lockers,LH wheels, chisels...i'm so jazzed,hope this was a good choice,if so i'ma get a 1/10 lcc Rat
01-27-2010, 06:31 PM | #15 |
well lets put it this way i have to buy another one cuz my boy love it !!!!check out the vid of him in the vid section ...I just got it today and im lovin it .. I have to wait till he goes to bed so i get a chance to play!
01-27-2010, 07:44 PM | #16 |
Ha....I guess I'm a 51 yr old kid....just leggo of my Losi
01-28-2010, 03:58 PM | #17 |
ok i rebuilt the stock shocks.. looks like there were already a internal spacer. ..I added a 1/4 spacer on the outside also and i put 30w oil ... all i had here .. im still not that impressed are you guys running clips on the stock shocks when i pick up the truck the springs extend and there floppin there like a 1/4 in space should i put a clip there to take up the space???? i like the threaded shocks im not gonna buy losi for the reports of them leaking which one would be a wise choice to get the job done?? Tonight i plan on cutting up a old body and gluing it to the upper link to make platforms for my electronics and moving the battery to the front.. |
