01-25-2010, 09:16 PM | #1 |
Newbie Join Date: Apr 2008 Location: Colorado Springs
| Another servo question...
I was wondering if anyone has used Futaba S3305 on their rigs? I just so happen to have one laying around, but havent seen any threads with info on this particular servo. I already replaced the stock servo that burnt after a month of usage. I will be installing a Castle Creations bec to help with the electronics. |
01-25-2010, 10:08 PM | #2 |
Rock Crawler Join Date: Dec 2009 Location: Lynnwood
SPECS: Dimensions: 1.6 x 0.8 x 1.5" (40 x 20 x 38mm) Weight: 1.7oz (47g) Speed: 0.25 sec/60° @ 4.8V 0.20 sec/60° @ 6V Torque: 124 oz-in (8.9 kg-cm) at 6V 99 oz-in (7.1 kg-cm) at 4.8V has about the same has the hitec 645 and ppl are running those without a bec |
01-26-2010, 11:10 AM | #3 | |
01-26-2010, 11:26 AM | #4 |
Newbie Join Date: Apr 2009 Location: Auburn
Get the CC bec and link then program the bec to 6v to maxinize the power to servo. Pull the red wire from servo and red wire from bec, connect together ( I use a folded in half staple ) don't forget to shrink wrap or tape. connect the servo to reciever as normal, power and ground for bec direct to battery. This way servo power is direct from batt controlled by bec without going thru reciever. |
