01-28-2010, 11:02 AM | #1 |
RCC Addict Join Date: Feb 2007 Location: Simpsonville, SC
| need help with skeeter setup
I need some help. I'm running a skeeter chassis on my mrc, but when i come to a steep incline it just wants to flip over backwards. Any tips?
01-28-2010, 11:31 AM | #2 |
Rock Crawler Join Date: Feb 2004 Location: Near Pittsburgh, PA
Get your COG as low as possible. More weight up front. You can try more foam in the rear tires. If they are a little harder, they won't grab as much as the fronts and flip you. I don't have that chassis , but I would put the rear links in the front lowest hole and leave the front where they are. |
01-28-2010, 02:46 PM | #3 |
Newbie Join Date: Aug 2009 Location: SAn Jose
I have read moving the front link down a hole i think helps squat the front helping it climb. I have a mini skeeter too love it. ive removed the weights from the rear wheels and have been thinking of adding a second wrap of weights to the front. All electronics are on rear axle battery on servo and got losi alum. shocks setting up now but read some where else to flip them so the shock body is on the axle low cog every little bit heps i guess
01-28-2010, 09:58 PM | #4 |
thanks, i will try thank |
