Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Mini-Rock Crawler
Thread: Losi aluminum hex width
Old 01-30-2010, 04:46 AM   #1
Default Losi aluminum hex width
Are the Losi aluminum hexes about the same width as the HR aluminum hexes? About 2mm wider than stock? THanks.
Prybar is offline   Reply With Quote
Old 01-30-2010, 10:17 AM   #2
I just measured mine. Stock hexes are 5mm wide; Losi aluminum hexes are 7mm wide. According to the Hot Racing site, their's are 8mm wide.
- Chris
Csnyder is offline   Reply With Quote
Old 01-30-2010, 12:28 PM   #3
are most of you running the wider hexes??? being a bit wider must help i would think ???
bigbeave1 is offline   Reply With Quote
Old 01-30-2010, 03:34 PM   #4
I picked up the Losi aluminum hexes, they seem to help a little.
SLODRIVE is offline   Reply With Quote
Old 01-30-2010, 03:47 PM   #5
I run the HR hex's and found them to work a lot better than the stock ones. Plus they are a clamping type hex
wheelhead4x4 is offline   Reply With Quote
Old 01-30-2010, 04:28 PM   #6
Moderator
JatoTheRipper's Avatar
I asked this question and was told the Hot Racing hexes are wider than the Losi hexes. They help a little, but they are a hassle. They would get stuck inside the hex on my stock wheels and pull off even though they're a clamping design. This happened no matter how much I tightened down the pinch bolt on the hexes.
To gain even more width and stability I eventually went to the wideners seen below. I like them, but at times the stock servo struggles to turn the wheels with the added leverage.
The link for them is http://www.tcscrawlers.com/2.2-Wheel...g-p-16233.html
Old 01-30-2010, 07:13 PM   #7
The Losi hexes use a set screw rather than a pinch screw. Personally I think using a set screw here works better as the hex doesn't distort, as would happen when a pinch screw is tightened.
My Losi hexes work great. Aside from the extra width and strength, they retain the cross pins when you remove your wheels - no more risk of losing cross pins when you're in the field.
- Chris
Old 01-30-2010, 07:21 PM   #8
Good info here. Never thought about the pinch screw warping the hex. Makes sense. Guess I will be going with losi on that part.
Ripperfi is offline   Reply With Quote
Old 01-30-2010, 08:14 PM   #9
I just put two washer between the wheel and the hex and it is working
great. And i have the stock plastic hexes.
stubs179 is offline   Reply With Quote
Old 01-31-2010, 10:13 PM   #10
Thanks everyone. I have never met a Hot Racing part that I liked so I would much rather go with the Losi design. I'll gladly give up the 1mm on each side.
