01-31-2010, 03:05 PM | #1 |
Rock Crawler Join Date: Dec 2009 Location: Jersey Strong!
| Front Weight
Is anyone adding weight to the front wheels like in a 2.2 or Super? If so how much?
01-31-2010, 04:04 PM | #2 |
Quarry Creeper Join Date: Mar 2009 Location: mesa
well i am running about 7 3/4 oz in each front and 1 oz in each rear
01-31-2010, 10:50 PM | #3 |
Pebble Pounder Join Date: Jan 2010 Location: Gluing my mirrors back on!
I have 2oz. of lead in each front wheel, nothing in the rears at this point.
01-31-2010, 11:31 PM | #4 |
Pebble Pounder Join Date: Feb 2005 Location: Chandler, AZ
02-01-2010, 12:53 AM | #5 |
02-01-2010, 04:05 AM | #6 |
Rock Crawler Join Date: Feb 2004 Location: Near Pittsburgh, PA
I was unhappy with the amount of space the weight took up in my Axial wheels...seemed like it made the foams baloon out and not gice like I wanted them to. I got some thick washers to use in place of the beadlocks. They weigh 2.5 to 2.7 oz. each. I have wideners on the front, so I will run the washer weights on each side of the wheel, and may out one washer on the outer face of the rear wheels. Just blasted them and painted them silver...not ugly, but not pretty either. |
02-01-2010, 07:08 AM | #7 |
02-01-2010, 07:12 AM | #8 |
Rock Crawler Join Date: Sep 2008 Location: Nashua,NH
Iam running 4.5oz in each front and 1.5oz in each rear. And it working great for me.
02-01-2010, 08:30 AM | #9 |
Rock Stacker Join Date: Jan 2010 Location: wallingford
I have 3 total in rear an and 3 in front i defently need to add more to front How much can i get away with with the stock servo?
02-01-2010, 09:05 AM | #10 |
RCC Addict Join Date: Oct 2007 Location: Kennewick, Washington
02-01-2010, 09:11 AM | #11 |
I wanna be Dave Join Date: Dec 2008 Location: anderson
i run 4 in the front an 2 in the rear an worked fine for me . now i have new alum wheels an i havent desided what to run yet they r so much heaver than stock
02-02-2010, 05:18 PM | #12 |
Newbie Join Date: Nov 2009 Location: Phoenix
I run 3 in the front and .75 in the rears and have not had any problems yet.
02-03-2010, 11:02 PM | #13 |
Rock Stacker Join Date: Jan 2010 Location: Canada
i have 1.75 oz of weight in each stock wheel(all 4 weighted) , 4.5 oz of weight from the stock battery placed over the rear axel, and 5.5 oz of weight on the front axel...my truck is much more sluggish and harder to turn than my friends but it crawls way better than his |
02-11-2010, 02:24 AM | #14 |
Rock Stacker Join Date: Jan 2010 Location: Dallas
| my 411
6.25 oz per wheel front 4oz rear per wheel. great stable rock crawling up and down and side ways. for straight up i run 40z per wheel front and 0 oz rear. mongoose 18.5 and jr d811 red servo 500mah eflite battery over servo and always run permanent 1.5 oz of lead weight on front axle. |
02-11-2010, 07:37 AM | #15 |
Quarry Creeper Join Date: Dec 2008 Location: Dalton
In the front I am running 3.3 ounces per wheel (all six weight) in the Vanquish LH Procomps in the front. The wheels and weight come in at 6.25 ounces before adding in the tire and foam weight. No weight in the rears but the wheel weights 2.95 ounces. |
03-05-2010, 06:12 AM | #16 |
Pebble Pounder Join Date: Nov 2009 Location: Jacksonville
I added a total of 5.07oz,mostly towards the front. Batt. on rear axle.
03-05-2010, 09:16 AM | #17 |
Rock Stacker Join Date: Nov 2009 Location: pueblo (P-Town)
I have 8.2 oz in each front and 5.0 oz. My rig is just bout 5 pounds and I'm running stock motor and servo it works great ill get a pic up soon
03-05-2010, 09:23 AM | #18 |
Rock Crawler Join Date: Aug 2009 Location: Thomasville, NC
03-05-2010, 01:41 PM | #19 |
Pebble Pounder Join Date: Feb 2009 Location: Hoodsport
i have 4oz in each front tire and 1.5 oz on my servo plate. battery on back axle and another oz on back 3 link stock motor, full size servo. this thing crawls up almost vertical walls
03-05-2010, 02:04 PM | #20 |
I used the washers as weights which allows the foams to do their job. Each washers is just over 2.5oz...running 2 washers per front wheel. Recessed the screws. |
