02-11-2010, 04:10 PM | #1 |
Newbie Join Date: Oct 2009 Location: Rochester Hills
| ESC only goes in reverse
Just took out motor/tran to adjust gear lash and hooked everything back up. Double checked wires, full battery etc. I have steering and reverse, but no forward at all. Loosened up clutch nut and no change. Motor wires are hooked up correctly. Running a slider motor and stock esc, tx. Ideas?
02-11-2010, 04:33 PM | #2 |
Quarry Creeper Join Date: Apr 2009 Location: Lillington, NC
Flip the switch on the top of the controller and see what it does then. You remote may have a bad connection for the trigger? Cole |
02-11-2010, 04:41 PM | #3 |
thanks, Ill try it
02-11-2010, 07:09 PM | #4 |
Looks like it was the esc. I think the stock one is fried. I put in an old one (also stock) that I had laying around and it works fine (for now.) thanks for the info though.
