02-13-2010, 09:11 AM | #1 |
Rock Stacker Join Date: Jan 2010 Location: Greer
| new speed control??
My old speed cpontrol burnt up and I just got my new one in.when I plug it in to the resever(sorry for spelling) it will go but when I plug the servo in the light blinks and won't do nothin
02-13-2010, 09:20 AM | #2 |
Pebble Pounder Join Date: Dec 2008 Location: Lake County
Is your servo bound up? Do you have another servo to try,maybe it's shorted out inside and causing issues?
02-13-2010, 09:26 AM | #3 |
I did and it would just jerk like it was only get power every couple seconds and the servo wouldn't work
02-14-2010, 02:36 PM | #4 |
Pebble Pounder Join Date: Feb 2009 Location: Hoodsport
what servo are you running
02-14-2010, 02:38 PM | #5 |
if you are running a full size servo you will need a bec i had the same problem when i upgraded i burnt up my esc got a new one and a bec and now i have no problems.
02-15-2010, 04:35 PM | #6 |
stock
02-15-2010, 05:34 PM | #7 |
i would try a new battery first and then if that doenst fix it try the bec
02-15-2010, 05:34 PM | #8 |
you could also try re binding it
02-16-2010, 07:19 AM | #9 |
i would have tried that but i kinda lost it |
02-16-2010, 07:21 AM | #10 |
its like it dont have to much power and the lipo is leaking
02-16-2010, 08:10 AM | #11 |
Pebble Pounder Join Date: Dec 2009 Location: North Wales
Lipo is leaking RUN, RUN NOW, RUN AWAY..... Or throw the lipo away........ Assuming your still alive and havnt been blown up or poisoned by a leaking lipo and that you have another battery to try..... Is it a stock ESC? Does your reciever light turn green and stay on (assuming stock reciever is in there still)? Do you have forwards and reverse ability if you leave the servo unplugged? |
02-16-2010, 11:06 AM | #12 |
hahaha,yea i can go forward and back but when i plug the servo in the rx light just blinks
02-16-2010, 04:28 PM | #13 |
Hmm, im going to state something a bit obvious but just checking, you have got the servo wires the right way round havnt you? Orange to the inside same as the ESC right? If you dont have another servo of some kind you can just plug in to try then it may be worth taking a trip to your LHS and seeing if they have one they can just plug in to check if thats the cause (so take your mrc with you when you go as I thought to do this once with another truck and forgot to take the darn thing with me, got some funny blank looks that day I can tell you). Anyway, Im going off topic, see if you can get another servo to just plug in for testing reasons, doesnt matter if its full size as it wont have any load on it so shouldnt be a problem. Then you will know straight off if its the Reciever or the Servo thats gone nuts. Im leaning towards a servo thats developed a fault inside like maybe a ground fault of some kind which is causing the reciever to light to go on and off like a Las Vegas sign. Check wiring, if ok try any sized servo, if still doing it with different servo then would be a trip for a new reciever I reckon. |
02-16-2010, 05:57 PM | #14 |
yeah ive tried that after about an hour of messing with it haha,but it still doing the same thing but thanks for the help ill go to a buddy house soon and check it out
