02-15-2010, 04:33 PM | #1 |
Rock Stacker Join Date: Jan 2010 Location: wallingford
| bec wireing
So how are you guys wireing it up i just got one for my mrc should i hook it up like this or a different way?? what should i have the voltage going to the servo set at ?? |
02-15-2010, 05:37 PM | #2 |
Pebble Pounder Join Date: Feb 2009 Location: Hoodsport
i have mine hooked up just like the directions say. and i dont think you can set the voltage on that bec.
02-15-2010, 06:04 PM | #3 |
Itsays on the site that you can choose what voltage .. ill have to check it out once i get it .. what servo are you running im thinking of getting the hs-5645 mg is there a cheaper one that is compairable to it ? |
02-15-2010, 06:35 PM | #4 |
Quarry Creeper Join Date: Apr 2009 Location: Lillington, NC
Castle Link allows you to set the voltage. I am getting ready to get one and seen in my castle link settings you can choose the BEC to modify. Cole |
02-15-2010, 06:43 PM | #5 |
Quarry Creeper Join Date: Dec 2009 Location: Jacksonville, FL
This is how I wired mine up. I had mine set to 6v when I bought it from Holmes Hobbies. I figured if your going to use one, might as well get the most out of it. Wiring it up like this is nice since it will only send 6v to the servo and not the receiver. I bought a 6" Y harness and cut it up and re-soldered it to make it plug and play with the receiver and servo. bigbeave1 did you get my pm about the battery? |
02-15-2010, 08:06 PM | #6 | |
Newbie Join Date: Apr 2008 Location: Colorado Springs
02-15-2010, 08:38 PM | #7 |
I wanna be Dave Join Date: Dec 2008 Location: anderson
mine just uses the sig. wire on the servo to the rec now
02-16-2010, 03:57 AM | #8 |
Pebble Pounder Join Date: Dec 2009 Location: North Wales
X2 on the diagram MRCnoob posted, works great that way |
02-17-2010, 08:17 PM | #9 |
im running the traxxas 2055 servo
02-22-2010, 04:18 PM | #10 |
wondering if there are any downfalls to wireing it the way castle says will it do any damage to the reciever ?? if hooked up that way figure id wire it like the designer sayed to pluss less work and wires
02-22-2010, 05:10 PM | #11 |
Rock Crawler Join Date: Dec 2008 Location: With the ATL Crawlers
You can do it either way. I personally perfer the castle way. Less work to do and there's really no difference. I've been running both my rigs this way for a while. And my 2.2 runs two servo's (dig). Set it at 6v and let it be |
02-22-2010, 08:16 PM | #12 |
thanks ill leave it !!!
04-19-2010, 09:53 AM | #13 |
Newbie Join Date: Jun 2009 Location: UK
I presume it's fine just to dissconnect the power output from the ESC and then run the bec into the aux on the RX to power both the servo and RX? I have done it this way because the BEC in my ESC is fried Cheers |
04-19-2010, 10:20 AM | #14 |
RCC Addict Join Date: Mar 2010 Location: Yelm
What if you bought a 5.x volt one? Is there a way to make it a 6 volt?
04-19-2010, 12:14 PM | #15 |
they all come with that setting from Castle but with a Castle link you can change it to 6 or whatever you want really. From looking at my book on it i didnt see any stick programming you could do to change it. So either buy a Castle link or find a buddy with one or order one from Holmes and request it to be set at 6. Hope that helps you out. Cole |
04-19-2010, 12:16 PM | #16 | |
Cole | |
04-20-2010, 08:38 AM | #17 |
nice one! I didnt cut the esc + wire though, i just dissconnected it from the plug, heat shrinked it and ziptied it outta the way |
04-20-2010, 11:59 AM | #18 |
04-20-2010, 12:04 PM | #19 |
Not really if yo clip the wire you just will have to hook it up to battery to connect it to the castle link. It just needs power and the battery gives it that. but either way is fine. I clipped mince since the pin was so tore up tryig to pull it. Hook the battery up once its connected to the castle link and im good to go for programming. Cole |
07-06-2010, 03:34 PM | #20 |
Pebble Pounder Join Date: Jun 2010 Location: belgium
i just fixed my broken esc and now i needed a bec because the print is damaged so i orderd a bec for the bec i need to disconnect the red wire so thats done now i connected the brown and orange kabel and going to instal a bec can i still use the castle link ? my esc is programmed with no drag brake at the moment and i need dragbrake for the G made i hope u can help me |
