02-18-2010, 08:38 PM | #1 |
Pebble Pounder Join Date: Nov 2006 Location: Hanson
| Losi Slider Motor VS Stock
I know the Losi slider motor supposedly has more speed than the stock MRC motor but does it have more or less low end torque than the stock motor for climbing? I have a scale truck that's heavy and I am looking for a more powerful motor for climbing.
02-18-2010, 08:50 PM | #2 |
Rock Crawler Join Date: Aug 2009 Location: crawlerado springs
| i have an mrc based scaler. im running the mini slider motor with a 10 tooth pinion. that lowers the wheel speed a little and gives you good torque! my little beast is almost 15 pounds and it still hauls a$$! i only get 20 min or so of run time with the mini slider on the stoc battery... thats the only down side...go for it! no mods needed, just get yourself a mini slider motor and get a 10 tooth pinion!
02-19-2010, 01:08 AM | #3 |
Rock Crawler Join Date: Dec 2009 Location: Lynnwood
my buddy is running the slider motor in his mrc and he goes through lockers like no other even the metal ones, the slider with a 2s lipo is faster then my 2s brushless and 3s brushed lots of wheelspeed but likes to bindup and break parts under heavy torque loads
02-19-2010, 04:52 AM | #4 |
I am running a stock battery in mine with no plans to run a lipo battery. My truck is about 6 1/2 lbs. I have metal lockers all around. I am running stock axles front and rear. I did grind my steering knuckles for more steering.
02-19-2010, 05:24 AM | #5 | |
Rock Crawler Join Date: Mar 2009 Location: Cottontown
I call total BS... Pics or your a liar | |
02-19-2010, 08:53 AM | #6 |
Rock Crawler Join Date: Mar 2009 Location: West of Eugene, OR
15lbs...? Interesting. Gearing down the pinion will help convert some of that wheel speed to torque. FWIW, I love my Stump Puller (with a smaller pinion). She puts out lots of torque and wheel speed - the stock motor doesn't hold a candle... Last edited by JeepinOR; 02-19-2010 at 08:55 AM. |
02-19-2010, 09:06 AM | #7 |
What is the "stump puller motor"? I was looking at the Holmes Hobbies motors and I thought about buying one of those.
02-19-2010, 09:24 AM | #8 |
my bad. i guess my hand scale is off! lol i thought it was heavier than it is. i just found the scale and its sittin at 6 pounds. i am also running two batteries, one for my winch and one for my motor. and i upgraded the lockers the first week to the steel lockers, got the slider motor a week later, lockers havent gone out yet. and that was 6 months ago! |
02-20-2010, 12:27 AM | #9 |
Rock Crawler Join Date: Mar 2009 Location: Frisco, Texas
02-20-2010, 05:16 AM | #10 |
Not saying its impossible, but consider... You'd have to make the chassis out of lead, links out of lead, wheels out of lead, then get a depleted uranium body, find shocks that could handle the weight, then the foams wouldn't support the weight, so you'd have flat tires. Then, you'd have to get some serious power behind it. And I know from experience a slider ain't gonna have the powere to drive it. Then your gonna kill your batteries making everything work so hard, so better step up to some serious nimh cells, (lipo won't work, were adding weight remember). Then, the driveshafts won't handle that much power, so upgrade em, doubt seriously anyone makes titanium driveshafts yet.... Then there's the whole servo problem. As much as I love the 645, it can't handle that much... Yeah, sure... it could be done, but then again... noone is that dumb |
02-20-2010, 05:51 AM | #11 |
I got a slider motor and a 10t pinion gear and tried to install it last night. The pinion mesh won't get tight enough because the motor can hits the tranny. Did you guys dremmel the tranny case to make it work? I put the stock motor and 14t pinion back in for my scale comp today. I am going to see if the hobby shop has an 11 or 12 tooth pinion in stock.
02-20-2010, 09:40 AM | #12 | |
02-27-2010, 11:07 AM | #13 |
Newbie Join Date: Dec 2009 Location: monroe, nc
what pinion are you guys using on your slider motors? i know its a 10 tooth but can i get a link?
02-27-2010, 01:52 PM | #14 | |
http://cgi.ebay.com/LOSI-LOSB1260-PI...item439b9b90c0 | |
