02-20-2010, 12:52 PM | #1 |
Rock Crawler Join Date: Jan 2010 Location: Arvada
| Questions about the GC3 chassis
Let me start by saying I'm wanting one of these bad. Everyone is saying that this is the chassis to have. I'm still new to crawlers and especially minis. My concern is that from all the reading i'm doing about them on here alot of people that have used this chassis are having problems with the build. Mostly sounds like the links and shocks don't mount up right and have binding issues. I'm not the best at customizing and coming up with fixes and it just bothers me that this awesome chassis doesn't work right out of the box like I would think it should. So even though I still want one this is a concern. Anyone else feel this way? I know that a big part of this hobby is customizing and tweaking but I think a brand new product should atleast mount up. I have the SWX chassis on my Axial and It was easy to put together and everything works great. Also please please don't get me wrong, i'm not bashing this chassis at all. I know it's gotta be great being it's the chassis that won the championship and all. And I am going to buy one, lucky for people like me all the experts on here share the tips and tricks for us that aren't as skilled. |
02-20-2010, 01:28 PM | #2 | |
Quarry Creeper Join Date: Dec 2009 Location: Jacksonville, FL
I bought and installed this chassis when the MRC and rock crawling was still very new to me, but I hated the torque twist. The only issues that I had with it were it came with 4 wrong screws (cone not button head) and the rod ends on the lower links were contacting on the skid. Both however are easy fixes. The screw issue is supposed to be fixed in the new run and filing away the sharp edge on the skip plate to fix the contact issue is very easy. It is a great chassis. It works well and I believe it is the cheapest complete conversion out there. | |
02-20-2010, 10:17 PM | #3 |
Rock Crawler Join Date: Nov 2009 Location: Wasilla Alaska
| patience
You cant go wrong the gc-3. Ive heard they addressed the binding issue in the second run of the chassis. Me i got the first run of the chassis. Took about 15 minutes with a piece of sandpaper, 5 washers, one 2mm spacer and the binding was gone.
02-20-2010, 10:25 PM | #4 |
Rock Stacker Join Date: Jan 2010 Location: Canada
i bought one about a week or so ago and was ready to throw it out tried taking the edge off the skid plate which helped slightly but the whole thing was bound up,none of the links wanted to move after a bunch of driving around to find parts and pieces i finally got my problems fixed, i located al the proper bolts that needed to be replaced from the ones supplied with the chassis. after that i replaced all the ball connectors for the rod ends with traxxas flanged ones everywhere,for whatever reason every single one that was supplied with my kit had a lot of drag on it and didnt want to move. i used all the rod ends that came in the kit and just replaced all the ball connectors i replaced the lower link to chassis rod ends to flanged also, then i ran 1 40 mm bolt through both links with a spacer inbetween the 2 links all my binding issues have been solved and now im loving this thing it has an awesome cog and the 4 link works very well the shocks still hit the upper links but i might make my own uppers or fool around with how the shocks are mounted edit: i also just noticed that my wheels hit the shocks when turned with some flex, i dont know if i should just use some wheel wideners but thats another thing you might have to mess with, it hit with both my stock losi wheels and darksoul's both with chisels mounted to them... Last edited by black92coupe; 02-20-2010 at 10:45 PM. |
02-21-2010, 04:02 PM | #5 |
Rock Crawler Join Date: Jun 2009 Location: SF
There are issues with any chassis. I Had some minor issues building mine but nothing too bad. You mention you are not much of a fabricator so the small issues you run across on this is the perfect place to start learning. I would bet it is very hard to design a chassis that works well with everyones shocks, steering, wheels, and still fit into the comp rules. It will always take a bit of tweaking to get going, have fun with it
02-21-2010, 11:26 PM | #6 | |
all good points and i'm definatley getting one. can't wait for them to be back in stock. | |
02-22-2010, 08:28 AM | #7 |
Newbie Join Date: Feb 2010 Location: Albuquerque
On the new run is it still true that the stock shocks won't work? I remember seeing a post somewhere that the stock shock won't work with the GC3...
02-22-2010, 12:42 PM | #8 | |
As to this thread, if you get one and need any pics of the fitting stuff I did, PM me and I'll photo any thing you may have issues with... when you get one. | |
02-23-2010, 11:51 AM | #9 | |
RCC Addict Join Date: Oct 2007 Location: Kennewick, Washington
02-23-2010, 02:20 PM | #10 | |
Rock Crawler Join Date: Aug 2005 Location: Illinois
All of the issues with the initial runs have been fixed on the kits coming into stock. J | |
02-23-2010, 06:50 PM | #11 |
sounds good. thanks for the re-assuring and like I mentioned I will be buying one as soon as someone gets them available I can't wait to see the improvement this chassis will make on the mini.
02-23-2010, 06:53 PM | #12 |
Rock Stacker Join Date: Feb 2010 Location: St. Joseph
Anyone know when the GC3 is going to be in stock?
02-23-2010, 07:04 PM | #13 |
Should be any day now.
02-23-2010, 07:05 PM | #14 |
Cool, ill keep a eye on tower.
