02-21-2010, 04:53 PM | #1 |
Rock Stacker Join Date: Mar 2009 Location: SGV, LA, CA, US
| MRC Issue Not Operating anymore...
Well I searched this forum for similar problems, most i have seen are in regards to binding issues or dead batteries. History; The crawler operated for quite some time on a 7.4v 1000mah lipo for almost its entire life thus far. Then one day it stopped working so I ordered a new ESC but got lazy to install it. Finally installed it and problem is still there. Problem: crawler does not operate. I turn on the crawler WITHOUT the bind plug the receiver light goes green and looks like its blinking soo fast it looks like its solid, or it could be solid not sure but none the less it does not operate. I turn on the crawler WTIH the bind plug and the receiver just blinks the green led two blinks, slight pause, two blinks, slight pause.... over and over... indefinitely. again no operation. The transmitter blinks orange and then goes solid as normal Solutions tried with no luck; Replaced ESC Made sure battery pack is charged Tried multiple battery packs Changed transmitter batteries Any suggestions??? Thanks in advance! |
02-21-2010, 06:59 PM | #2 |
Rock Crawler Join Date: Mar 2009 Location: Frisco, Texas
check your plugs... this happened to me alot... the plug into your reciever may be upside down ;) that happened to me and when i flipped it it worked again .. if it doesnt work then i dont know.. sorry
02-22-2010, 09:57 AM | #3 |
Rock Crawler Join Date: Oct 2006 Location: Fernley
| As shadow stated or also make sure that the plugs are in the correct spots. I have put the esc plug in the aux/battery slot and had a similar issue.
02-22-2010, 08:18 PM | #4 |
Rock Stacker Join Date: Jan 2010 Location: wallingford
are you sure the lipo is good??? if your running the stock esc with no voltage cutoff you battery may be shot
02-22-2010, 10:10 PM | #5 |
Newbie Join Date: Jan 2010 Location: Omaha
Your description of the problem is identical to the problem I had with a faulty Tx. Lucky for me I had just bought my MRC and so my LHS swapped out the controller for a new one, no questions asked. I haven't had the problem since. Try a different controller and see if that is the problem. I would call Losi and see if they will give you a new one under warranty.
