02-24-2010, 09:14 AM | #1 |
Quarry Creeper Join Date: Aug 2008 Location: Up your tail kicking footballs!
| Problem with motor??
I just finished my MRC and have a FXR with HH 33 t motor running off of a tenergy 2s lipo. The problem I am having is that the motor will run finebut it acts as if it has a bad spot in it because it will stop at a certian point and will not go again untill I turn the tires to get the motor in a different spot on the armature. Any sugestions? Thanks in advance.
02-24-2010, 09:35 AM | #2 |
Search button works wonders doesn't it!!lol
02-24-2010, 11:07 AM | #3 |
so you get it figured out yet
02-24-2010, 01:27 PM | #4 |
Not yet, I ran it around on the floor for 15 more min to see if I didn't let the brushes break in long enough. Also checked my pinion mesh to see if it was to tight but still nothing. Any sugestions??
02-24-2010, 01:40 PM | #5 |
I would check the drivline, so take off the motor pinion and spin the drive train real sloooow see if you find a rough spot. if so disconect one driveshaft and continue to find out if its comming from the front or rear. also you can check your gear mesh. you want contact but not tight. I have had a rough pinion that I had to sand a touch to smooth out. |
02-24-2010, 01:50 PM | #6 |
Rock Crawler Join Date: Jun 2009 Location: vacaville
it might be the motor I had the same problem with one was told there was a bad batch made I got a new motor everything works great now. talk to Mr. holmes he can help ya with it . he helped me.
03-12-2010, 07:23 PM | #7 |
Rock Stacker Join Date: Sep 2009 Location: tacoma
mine dose the same exact thing im suposed to be at a comp tomorrow morning and im gonna get a lot of touch points if i have to push it past the dead spot every time
