03-02-2010, 07:05 PM | #1 |
Newbie Join Date: Feb 2008 Location: crawlertown
| best MRC chassis for lowering / lengthening WB?
looking for the best chassis to lengthen the wheelbase on my MRC and to lower it a bit. this will not crawl in comps so compliance is not an issue right now. suggestions? |
03-02-2010, 07:24 PM | #2 |
Rock Stacker Join Date: Jun 2009 Location: Utica
03-02-2010, 10:01 PM | #3 |
Newbie Join Date: Feb 2010 Location: Colorado
sucks they're out of the wideners
03-03-2010, 01:40 PM | #4 | |
| Quote: wonderful. got the wideners already ... ill pick up the chassis now ... exactly what i wanted in a chassis. | |
03-03-2010, 07:22 PM | #5 |
EDIT: also looking for the absolute smallest pinions and the largest spur gear i can find. right now i have a 10 tooth pinion and the largest LOSI spur gear (60T). anyone know where i can find these? i have a CC mamba micro pro and its cogging like an ignorant monkey watching cheap porn .... i seriously need this fixed, and the ESC programming is not cutting it. i have found Hot-racings 62T spur gear and 9tooth pinion .... but im going to need better gearing than that. any other options out there? thanks. Last edited by jonesy; 03-03-2010 at 07:35 PM. |
03-08-2010, 12:23 PM | #6 |
bump ... anyone know the smallest pinion manufactured for the MRC? and the largest spur gear?
04-11-2010, 04:15 PM | #7 | |
bump | |
04-11-2010, 08:21 PM | #8 |
Rock Stacker Join Date: Mar 2009 Location: SC
ive got those wideners. they are way to wide. took em off after one run
04-12-2010, 08:35 PM | #9 |
Pebble Pounder Join Date: Aug 2009 Location: state of confusion
if you want your car that mush bigger you should get a 1/10 car insted. but i can see why you did not becouse the losi is AMAZING!!!
