03-03-2010, 08:06 AM | #1 |
Newbie Join Date: Oct 2008 Location: Turkey
| MRC "motor noise" and L-trail chassis "drive shaft" Hello, I have a stock Losi Mini Crawler and would like to know two things: 1-) The stock motor is very "noisy", what could I do "to decrease" the noise from the motor?? Would using the "Holmes Hobbies Mini Torque Master" help decrease the noise or some other motor or any other method?? 2.) I would like to order the "TCS L-Trail chassis", but as far as I know the "stock drive shaft" is not fitting the extended L-Trail chassis. Is there a shaft I can order that would be a direct fit to the scale chassis?? And what else would I need to order? --------------------------- Savage X 4.1 Mini Lst2 (Silver) Mini LST2 (Red) Tamiya Hotshot Wheely King Based fj40 Scale Crawler Losi MRC |
03-03-2010, 07:40 PM | #2 |
Quarry Creeper Join Date: Apr 2006 Location: SLC, Utah
Not sure about the motor I still use the stock I just recived the L-trail chassis the other day. As for driveshafts Ive heard that ones for a Stampede work
03-03-2010, 07:42 PM | #3 |
Adilynsdad too! Join Date: May 2004 Location: G ville
Get one of the motor mufflers from JRH... They work great but make sure to keep the muffler bearing lubed! |
03-03-2010, 07:51 PM | #4 |
Rock Crawler Join Date: Mar 2009 Location: Frisco, Texas
hmm mine made a LOUD noise for a LONG time then i used paper on the slipper clutch to do the mesh for gears now its quiet as a mouse the torque mini master i believe is just as loud |
03-03-2010, 08:01 PM | #5 |
Pebble Pounder Join Date: Jan 2010 Location: Gluing my mirrors back on!
My MRC is just as loud with the Mongoose as it was with the stock motor...setting the gear mesh and greasing the transmission gears helped a little though. You want part numbers for longer driveshafts? Order 2 of Traxxas #1539R and 1 of #1951, then cut them down to fit. They'll look like this: |
03-04-2010, 02:29 AM | #6 |
thank you all for the information you provided, So I will mesh the gears with paper and also grease the transmission. (I mainly have used 540 size motors with 27t, 45t, and 55t. they are all very quite, the noise of the small motors are sort of weird) most of you say that the mongoose and the torkmaster are also loud, so there is no sense then for me to order them, so thats out of my plan now. as to the driving shafts, thank you sloddrive for the partnumbers and picture, been of great help, I am going to order them together with the L-trail chassis. |
03-04-2010, 04:38 PM | #7 |
Pebble Pounder Join Date: Feb 2009 Location: Hoodsport
another way to extend your driveshafts is to get another set of the stock drive shafts and glue them together. there are some threads on here that will show you how
