03-04-2010, 09:35 AM | #1 |
Newbie Join Date: Jul 2009 Location: Harrisburg
| MRC Steering issue
I need help trying to get the steering "right." I have moded my 1.9 MRC with Losi alumin Cs and knuckles. Integy aluminum steering link (some may say integy is the prob it isn't.) when looking at the rig from behind and the steer is to the right the left wheel points further right the the right wheel causing a wide steering radius. When steering to the left the oposite happes, the right wheel points further left than the left when again, causing a widesterring radius. I removed the Integy links and made titanium links the same length as stock...same thing. Any idea of where to look, suggestions...help! Thanks. |
03-04-2010, 10:05 AM | #2 |
Quarry Creeper Join Date: Mar 2009 Location: mesa
i kept breaking the small bolts so i drilled them to 3mm and used traxxas parts to have a adjustable drag and toe links that cured my problems steering and durability
03-04-2010, 10:11 AM | #3 |
Pebble Pounder Join Date: Dec 2009 Location: North Wales
Redrill the knuckles so that the bolt sits in a straight line in front of the pivot points on the knuckle. This will correct the problem you are describing and make both wheels turn the same amount left and right. If you do a search for redrilled knuckles you should be able to find some pics. |
03-04-2010, 11:04 AM | #4 | |
Quarry Creeper Join Date: Dec 2009 Location: Jacksonville, FL
Here's a link to the thread: Steering Ackerman..REdrill knuckles | |
03-04-2010, 07:39 PM | #5 |
Rock Stacker Join Date: Jan 2009 Location: Mesa
x2 works great! Use a drill press if you have access to one. not much material if you dont get the hole dead center.
03-05-2010, 02:53 PM | #6 |
| thanks
Thanks for the input everyone. The link was especially helpfull. No access to drill press but there is a hobby shop near me where they are very resourceful.
03-05-2010, 03:08 PM | #7 |
I just used a hand drill. You guys are fancy with the drill press.
03-05-2010, 07:25 PM | #8 |
Pebble Pounder Join Date: Feb 2010 Location: West Orange
Read this forum last night and just took the truck outside and realized I had a problem. Dang! never noticed it before.
03-06-2010, 02:45 PM | #9 |
the metal is soft enough i just used a pinvise with a 3mm drill bit
03-06-2010, 02:54 PM | #10 |
Pebble Pounder Join Date: Jul 2005 Location: Warrington, UK
03-06-2010, 03:47 PM | #11 |
