03-05-2010, 12:58 PM | #1 |
Ultimate RC Decals Join Date: Aug 2005 Location: San Antonio
| GC3 Live Build
if you guys are board please feel free to drop in and take a look at a build i'll be doing all day today. i'm going to swap my slingshot chassi'd 1.9 to a GC3. the feed will be on as i work on it. and from time to time i will need to get away from the build to do other things. so please be warned this will not be a fast build. no on to the link. http://www.ustream.tv/channel/bowtie specs. GC3 Chassis Losi Late Model Shocks with rod end mod Losi MRC Stock Springs 1.9 Rovers 1.9 CI Foams 1.9 Vanquish LH's Hitec 5955 servo Novak Mongoose system 3s lipo all Losi Aluminum Upgrades Spektrum RX etc..... Last edited by BOWTIE; 03-05-2010 at 09:02 PM. |
03-05-2010, 01:30 PM | #2 |
i ran into a problem with the screws for the skid. on stripped. i need to find a replacement for it.. quick tip: before mounting the skid, use a 3mm tap and tap the srew holes about halfway into the skid. that will make the screws go in alot easier. |
03-05-2010, 02:28 PM | #3 |
Build faster and talk more!
03-05-2010, 02:29 PM | #4 |
bahh i'd rather build slow and talk less. besides my damn bird is load enough.. |
03-05-2010, 02:34 PM | #5 |
I hear your TV, and the sound of screws stripping plastic. Oh, I hear the birdie now. |
03-05-2010, 02:56 PM | #6 |
Newbie Join Date: Nov 2006 Location: Warren
needs more light. other then that cool.
03-05-2010, 03:02 PM | #7 |
03-05-2010, 04:43 PM | #8 |
Rock Crawler Join Date: Aug 2005 Location: Illinois
Your skid holes are not drilled correctly from the factory. They should be through holes and no need to be tapped. J |
03-05-2010, 04:46 PM | #9 | |
i tapped to make it easier to start the 3mm screw. i also had binding issues with the skid and non flanged ball ends. i used some flanged ends and one nut in between instead of the two. i'll get pics in a bit. | |
03-05-2010, 04:52 PM | #10 |
pics i did the rodend mod to the short late model losi shocks so i could use them with this chassis.. |
03-05-2010, 05:00 PM | #11 |
how it sits right now.. now i need to wire it all up and mount the body.... |
03-05-2010, 05:45 PM | #12 |
What I mean is the holes are supposed to be "through" holes. The screws should pass through the holes not thread into them. Nice job on the skid. Build is looking good J |
03-05-2010, 08:10 PM | #13 | |
thanks. i'm almost done.. all wiring is done. body mounts are all that's left. | |
03-05-2010, 08:19 PM | #14 |
back on again.. lets see how long this lasts...
03-05-2010, 08:27 PM | #15 |
Rock Crawler Join Date: Jun 2009 Location: SF
What a great idea, your gc3 is the twin of mine, same wheels, esc, motor I even think we have the same servo! Mine is not a Texan though!
03-05-2010, 08:53 PM | #16 |
03-05-2010, 08:58 PM | #17 |
the rig is now GC3'd... Last edited by BOWTIE; 03-05-2010 at 10:29 PM. |
03-05-2010, 09:52 PM | #18 |
Rock Stacker Join Date: Dec 2009 Location: Redmond
Nice job with the skid using the flanged balls. Im going to steal this idea for my build. Nice pics.
03-05-2010, 09:55 PM | #19 |
Quarry Creeper Join Date: Dec 2005 Location: San Antonio
coming out sweet cant wait to see this one on the rocks..
03-05-2010, 10:30 PM | #20 |
