Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Mini-Rock Crawler
Thread: does it work ? Tekin FXR + 3S
Old 11-07-2011, 01:12 AM   #1
Default does it work ? Tekin FXR + 3S
Hey fellas,
I got the Tekin FXR and the HH MiniTorqueMaster 22T or 33T (donīt know how to figure out).
Can I drive this set with 3S?
Tekin says a 35T is needed for 3S but why?
What can happen?
WeekendWarrior is offline   Reply With Quote
Old 11-07-2011, 11:45 AM   #2
I had the same set up for a while, I ran it with a 3S for quite a while just fine. I am not saying for sure that it was right, But it worked fine for me. Now I am running the FXR with a 17T contraband it that thing ROCKS!!. The FXR had been running a 3s just fine.
Airbornejordan is offline   Reply With Quote
Old 11-07-2011, 12:23 PM   #3
The 35T limit refers to a 540 size motor. The smaller can motors are safe to use on 3S at those winds you are talking about,
AreCee is offline   Reply With Quote
Old 11-07-2011, 01:09 PM   #4
3s and 22t hhtmm will be VERY fast at the wheel! I ran the 22T on 2s and was more than impressed with wheel speed!.
Gfresh is offline   Reply With Quote
Old 11-07-2011, 01:40 PM   #5
Originally Posted by WeekendWarrior View Post
Hey fellas,
What can happen?
Thats what I run and it is pretty darn quick so the learning curve was a tad higher. I used to run a 2s and it was plenty.....come to think of it why did I even go 3s in the first place. I think it is overkill but to each his own.
DRCrawlGood is offline   Reply With Quote
Old 11-07-2011, 06:38 PM   #6
I would agree with Arecee regarding the size motor having an impact on what tekin says about a 35t. I had a 33t on an fxr running a 3s and it was more than fine. I had to really tweek the epa's to make sure I copuld control my rig. I had a dx3r and would use the epa's while driving to really slow things down and when I needed to wheel and get air or jump a gap or something I would goose it and roll the epa up to 140%. It was a great setup. I wish I had decased my fxr though to get it even smaller.
RickM is offline   Reply With Quote
Old 11-08-2011, 12:35 AM   #7
Iīm thinking about driving it with 3S to drive a smaller pinion and a bigger spur gear so that I can crawl a bit slower with higher rpmīs and when itīs needed thereīs enough push and speed to jump obstacles
How can I figure out which HH MTM I have?
Old 11-08-2011, 10:23 AM   #8
Slightly off topic but what pinions fit the Holmes motors? I am running a Losi Slider motor right now but have a Holmes and want to put it in but need to fina a pinion. Also, what count tooth seems to be working?
Scottmisfits is offline   Reply With Quote
