04-11-2010, 09:35 PM | #1 |
Rock Stacker Join Date: Jun 2009 Location: Agoura Hills, CA
| TCS Crawler Mini Edge tuber setup question
I'm in the process of setting up my TCS Mini Edge chassis. Using the stock shock mounts I can only mount the rear shocks outboard of the chassis. In all of the pics of seen of the mini edge the shocks are mounted inboard, both front and rear. Is there any problem mounting them this way or should I pick up whatever is needed to get the shocks inboard. I'm running the Losi threaded shocks with internal springs. Thanks guys! |
04-11-2010, 10:55 PM | #2 |
Newbie Join Date: Oct 2009 Location: Ventura County
I run the shocks on the outside on my TCS Tuber. I also run the shocks on the outside of the stock location on the axles. I used longer 2mm screws to reach the threaded side. This will keep the shocks slightly inboarded and will also help with the torque twist.
04-12-2010, 04:42 PM | #3 | |
