04-20-2010, 09:44 AM | #1 |
Rock Stacker Join Date: Nov 2009 Location: seattle
| pinion shim
I stripped out a metal pinion in my rear axle. I replaced the gear and started reassembly. I noticed with the axle clam shelled back together that the pinion shaft has some movement in and out. I looked at the front and it was worse. Has anyone added shims to try and tighten this up? I think it may be why my rear pinion failed.
