08-05-2010, 06:57 PM | #1 |
RCC Addict Join Date: Mar 2010 Location: Yelm
| axle swap??
Has anyone ever ran a set of axial axles on a Losi mrc? Just curious. If you have, can you post pictures??? |
08-07-2010, 02:47 AM | #2 |
RCC Addict Join Date: May 2010 Location: Los Altos, California
i dont think its really possible to do so unless you modifiy the axial Axles to fit the MRC.. But ive read someone has Used the Traxxas Axles as a replacement.
08-07-2010, 09:24 AM | #3 |
The trick would be to get the output shafts to mate with the Traxxas U-joints. It is a lot easier when you are going from a larger out to a smaller U-Joint (Example: E-Maxx tranny to 'pede drivelines), but when you are going from a smaller output to a larger U-Joint you have to find a way to fill the gap, JB wled, maybe? Why would you want to? It would be easier to get a set of Axial axels and tranny and just shorten the WB. With that said, build what you are thinking about and put together a build thread, we love to see custom work. Last edited by Greatscott; 08-07-2010 at 09:26 AM. |
08-07-2010, 09:57 AM | #4 |
0 0 Join Date: Jul 2006 Location: FT. Thomas
Traxxas villain u-joints will work on the Traxxas / Axial drive shafts but have the smaller output shaft hole. Other than that, making some new links to work and you have Axial axles on your MRC. http://www.rcplanet.com/Traxxas_U_Jo...p/tra1539r.htm |
08-07-2010, 12:09 PM | #5 |
08-07-2010, 12:14 PM | #6 |
I already have traxxas driveshafts on my MRC, so I figued I got a head start there. That seems to me like the only troublesome part of the swap(not really though). Links will be easily converted. Why am I doing this?? I was thinkin, it is kinda like throwing full width axles in a Toyota or throwing Toyota axles in a Samurai. I also want to build a Jeep Tube chassis, and it would be easier with wider axles. Will start a build thread as soon as the axles arrive |
08-07-2010, 12:21 PM | #7 | |
| Quote: That is very cool! I am going to try these thing as full width, but if they end up being too wide, I may attempt it...... | |
08-09-2010, 03:30 PM | #8 |
Oh boy! These things are huge!!! An MRC axle with tires on it, almost fits between the tires on my axial axle. I don't think I will be running my new 1.9 Rovers anymore(little too short) |
