08-21-2010, 04:22 PM | #1 |
Rock Stacker Join Date: Mar 2009 Location: SC
| GC3 Chassis trouble
anyone have trouble puttin the lower links on the chassis or am i just going about it wrong? it seems like it wont fit. let me know if anyone has some suggestions
08-21-2010, 07:45 PM | #2 |
Newbie Join Date: Jul 2010 Location: Tulsa
I felt the same about mine. But once you rotate the axle back to connect the driveshaft they fit right in.
08-21-2010, 08:03 PM | #3 |
Are they binding ? You may have to sand the edges where the rod end bolts to skid plate to clear. |
08-21-2010, 08:30 PM | #4 |
RCC Addict Join Date: Jun 2008 Location: Amish Buggy PA
I had some troubles putting mine together, some pics or better description of the problem would help out alot.
08-22-2010, 06:28 AM | #5 |
Quarry Creeper Join Date: May 2010 Location: Longmont, CO
Not sure the issue, but i have seen a few people that need to take a bit off the skid to get them on.
08-22-2010, 07:31 PM | #6 |
If you are having trouble putting the nuts on make sure you are using the non lock nuts...It will never fit with the locknuts.
08-22-2010, 08:21 PM | #7 |
i got it togather today. had to trim it up some but thanks for the help. i was having trouble getting the nuts on
08-22-2010, 08:28 PM | #8 |
RCC Addict Join Date: Jan 2010 Location: Dallas
I actually took a couple of the losih rod ends, heated them up and bent them to avoid binding under articulation. Getting them mounted though was not a problem.
