04-26-2012, 07:52 AM | #1 |
Quarry Creeper Join Date: Feb 2011 Location: The underground
| mrcp with bent links Q's
Last night I put bent links on my pro and it feels like it doesn't cycle properly. The links don't make contact, and ideas? |
04-26-2012, 09:53 AM | #2 |
Quarry Creeper Join Date: Jan 2011 Location: Kingston NH
| Re: mrcp with bent links Q's
just a guess is the hardware to tight iv always tighten it till it touches the mounts and stopped
04-26-2012, 10:10 AM | #3 |
That's a good idea, I sometimes have that problem
04-28-2012, 12:49 PM | #4 |
| Re: MRC Pro with bent links Q's Until they loosen up, the ball in the rod ends can be a bit tight. I use Lock-Eze which is a liquid graphite lube. It goes in easy, cycle the joint, wipe off excess. Since you're just tightening a screw through a steel ball in the rod-end, it really won't make a difference how tight it is....it's how tight the ball is in the plastic. If you leave the screws loose, you are rotating the ball on the screw, not a good thing long term. |
04-30-2012, 06:19 AM | #5 |
What I thought was bind turned out to be the inverted shock cap hitting the axle mount. I realized i need to outboard the shock mounts.
mrcp with bent links Q's - Similar Threads | ||||
Bent links or not bent likes that is the question? | Ktbone | Newbie General | 67 | 01-06-2012 05:10 AM |
bent links or straight links | legion1capone | General Crawlers | 11 | 01-21-2010 04:32 AM |
Be careful with your Losi bent links / DIY bent links as a result | Russ | Losi Mini-Rock Crawler | 14 | 01-06-2009 04:43 PM |
Q's on steering links | jeep_boy02 | General Crawlers | 0 | 08-03-2004 09:38 PM |
