10-02-2010, 10:32 PM | #1 |
RCC Addict Join Date: May 2010 Location: Los Altos, California
| Diff problems... AGAIN..
alright, im really getting annoyed by my Diffs.. the Pinion and the sun gear i think its called always clicks and then its back to square one, by going to the LHS... 1.. I've Shimmed the pinion a bit, but no luck, either Binds or not enough.. 2.. Greased and properly maintained.. 3.. All screws are tight, so no way to make the diff move while in motion.. I dont know what to do now.. since ive already spent close to $50 just replacing the diffs gears.. its just annoying the crap outa me What can i do?? |
10-02-2010, 10:53 PM | #2 |
RCC Addict Join Date: May 2009 Location: In the warmth!
I move the shim from the outside of the output shaft to the inside, behind the pinion. Also nut & bolt axle cases together. Don't have any problems until the pinion wears. And that depends on how much useage and abuse I give it. |
10-02-2010, 10:58 PM | #3 | |
grrr may have to contact losi on this one.. >.< | |
10-02-2010, 11:11 PM | #4 |
I would suggest you check the bearings in the axle housing at the output shaft.There is 2 bearings there,if there is much play then the pinion can move and lose its contact patch.It wouldnt hurt to check all the bearings while you have it opened up. also the diff may have play inside the housing. with the housing opened up.place the diff in one side at a time and see if it can move/slide side to side any.If the diff has play it can also couse lose of contact surface. |
10-02-2010, 11:27 PM | #5 | |
grr, but the diff casings are barely old.. maybe 5-10 runs.. in a span of like 5 months? | |
10-03-2010, 12:29 AM | #6 |
After doing the nut and bolt trick I have not had any more problems. Once you have upgraded electronics you need to add the nut to make sure the housing doesnt flex. You can also make your slipper a little looser so it will go easy on them.
10-03-2010, 12:55 AM | #7 | |
need to find a way to not kill diffs.. | |
10-03-2010, 06:55 AM | #8 |
10-03-2010, 08:41 AM | #9 |
10-03-2010, 10:19 AM | #10 |
RCC Addict Join Date: Mar 2010 Location: Yelm
Replace your diff. pinion. It might not look wore out, but that is your problem. Once you pull it out, take a good look at it, you will see what I am saying. |
10-10-2010, 02:29 AM | #11 |
Soooo????
10-10-2010, 10:02 PM | #12 |
10-11-2010, 07:18 AM | #13 |
| nice. Got it in time |
10-12-2010, 10:02 PM | #14 |
Newbie Join Date: Aug 2010 Location: spok
i started clicking today , and am hoping that it is a simple fix like this...... |
10-12-2010, 10:14 PM | #15 |
11-13-2010, 12:35 PM | #16 |
negative ghost rider.front pinion gear is toast.need to buy a set of gears i guess.hoping that they are not TO expensive.i cannot find them anywhere on losi's site.maybe i am searching wrong, i found them one time before.on the search for sure.cheers
11-13-2010, 01:14 PM | #17 | |
11-13-2010, 02:02 PM | #18 |
yeah , i'm dumb. i went searchin and found'em right quick after i posted that .dumbass.anyways, thanks.cheers
11-13-2010, 02:05 PM | #19 | |
| Quote: | |
11-13-2010, 04:01 PM | #20 |
That is the new "Overdrive" pinion gear.
