10-21-2010, 09:42 AM | #1 |
Quarry Creeper Join Date: Apr 2009 Location: Hampshire, UK
| EC3 vs Deans
I've just managed to source a brand new sidewinder for my Mini Wedge and need to decide on connectors for the motor and battery. I'm using Deans on my other trucks but wonder if anyone is using or has thoughts on using EC3 connectors instead. I like Deans but they are a bit of a pain to solder and disconnect. What are you using and why? Cheers, Neil Last edited by neiloid1; 10-22-2010 at 05:39 AM. Reason: Crap thread title |
10-21-2010, 09:55 AM | #2 |
I use the micro deans for my battery and BEC connections...but I use banana plugs for the motor leads.
10-23-2010, 12:28 AM | #3 | |
RCC Addict Join Date: May 2010 Location: Los Altos, California
for the Motor, i use bullet connectors.. if i were you, id just solder on Deans.. even though their a pain to solder on, its much better than switching all your ESC's to another connector, and having to buy banana connectors for your charger... as for the EC3, not many people use them. i personally dont like them, they just look alittle weird IMO and im pretty sure you could get the polarity switched pretty easy, compared to Deans or TRX. | |
10-23-2010, 04:02 PM | #4 |
Quarry Creeper Join Date: Aug 2009 Location: here
I'm useing polorized micro deans for the battery and usually hard wire in the motor to the ESC, Saves money and space. I do wish Deans made a mini plug. The micro seems a little small and regular deans are too big IMO.
10-23-2010, 04:25 PM | #5 |
10-23-2010, 04:27 PM | #6 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
If you are already deans. Why would you even question what conector to use. Deans would save you alot of headach. I use deans on all my esc's and motor's so swapping any of my motors in is no problem. Or even swapping a whole esc. The Chinese deans plugs are just as good IMO and work just fine with real deans plugs. A dollar a piece sure beats $5 for a deans at the LHS
10-26-2010, 04:38 AM | #7 |
Thanks for the replies guys. My CC Sidewinder arrived yesterday with it's lovely little gold bullets for the motor so I'll be rewiring my stock motor and Losi Insane motors with thicker wire and CC bullets. As for the battery connectors I'm moving to Lipo which gives me the opportunity to look at other connectors for my crawler whilst keeping my NiMhs for the trucks. Probably will stick with Deans but the ribbed ones for easier splitting and that they are that much cheaper, unless others can convince me otherwise.... |
10-26-2010, 04:48 AM | #8 |
Quarry Creeper Join Date: Oct 2009 Location: Athens
Another deans user here. Re-soldered all my new batteries with deans connectors yesterday, as Fred said all my other batteries, Esc's and charge leads are already deans so it was no contest really. I tried the ribbed deans but found they were a nightmare to solder, the plastic seemed to have a noticeably lower melting point than the other deans copies knocking around. I have experimented with going around the plug with me soldering iron marking up the plastic. To be honest though in my case i didn't find it helped much so i no longer bother. I tend to find i need to pull the wires instead But my situation is a little different than most others. Cheers Mark |
10-26-2010, 01:22 PM | #9 |
Quarry Creeper Join Date: Mar 2010 Location: Yay Area
My soldering jobs always end up looking like gobs of chewed bubble gum! I did both TRX and Deans plugs and found the Deans to be easier even on thicker wires. TRX plugs are a b!tch to solder though no matter what. Micro Deans? Sheesh I melted about four plugs before I finally got lucky and did one up OK |
10-26-2010, 01:26 PM | #10 |
| When I solder deans, I connect two together (one male, one female), then solder. The opposing connector helps keep the contact points from moving around if you are having to heat up the point for longer periods of time.
10-26-2010, 01:40 PM | #11 | |
If i'm not doing battery connections i'll also hold the non soldering end in a small hobby vice as well which acts as a heat sink. Still the plastic case melted on the ribbed type. To be honest i've soldered hundreds if not thousands of deans connectors over the years and it's only the ribbed type i've experienced any problems with, they just seemed to be made out of softer plastic that melted at a lot lower temp Weird. | |
