Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Mini-Rock Crawler
Thread: Braze or weld?
Old 11-17-2010, 10:57 AM   #1
Default Braze or weld?
I am looking into building my own tuber, and wondering do you guys braze or weld? If you weld what kind of welder? I was looking at a small cheap one from harbor freight (wire with no gas). Brazing sounds easier though.. I really rather build my own rather than buy. Buying everything makes me forget the essance of the hobby...
ronj18 is offline   Reply With Quote
Old 11-17-2010, 01:21 PM   #2
I braze and its easy but holding the pipe at an angle and using both hands to blaze is difficault with out any triangle magnets but some guys I've seen in build threads use tig welders which seems easier because the welding rod is inside the welder but unless you work at steel mill or a factory you probly dont have a tig welder
geekfreek95 is offline   Reply With Quote
Old 11-17-2010, 03:42 PM   #3
thanks I will try brazing first. Seems to be cheaper as well.
Old 11-17-2010, 05:56 PM   #4
yup some map gas and the smallest brazing rod you can find
Old 11-18-2010, 04:10 PM   #5
After staring at my broken mrc I think I will make a tuber based off the lexan body, like how the blue lines run on the body. A more realistic look I think.
Old 11-20-2010, 09:50 PM   #6
Brazing is fun! I am working on a tube chassis desert truck right now and its going great! I picked up some 3/32 and 1/4 brake line for my built. I'm using oxy-acetaline torches with a very small tip and some 45% silver brazing compound rod. Its working great, just remember you MUST use flux. Good luck, enjoy
crazyracer is offline   Reply With Quote
