11-26-2010, 12:39 PM | #1 |
Pebble Pounder Join Date: Apr 2010 Location: Manitowoc
| Servo strength
Ok guys I've searched but can't find the info. What is the minimum oz/in rating for a 1/10 servo in comp MRC?
11-26-2010, 06:18 PM | #2 |
Quarry Creeper Join Date: Jul 2008 Location: Sedro Woolley
what ever your budget can afford really. i started out with a jr z590m which buts out like 80oz torque but now iam running a jr st126mg which puts out 145oz torque and lots of guys run a hitec 645mg. other guys are running some in the 300 range and some in the 400 range.
11-26-2010, 07:18 PM | #3 |
Newbie Join Date: Dec 2009 Location: Louisville
Well you start out with a stock truck. Add some weight to the tires, then some bigger tires, softer foams, and before you know it the thing won't steer especially in the rocks. I run a Hitec 7954HS 330 oz @ 6 v. It runs about $100 but you won't be dissapointed. Just be sure to use a Castle Creations BEC to power the servo or it will overload the built in BEC in your ESC unless you have a Novak Rooster or something like that. I run with some guys that use sronger steering servo's than mine but none weaker. |
11-26-2010, 07:29 PM | #4 |
Quarry Creeper Join Date: Apr 2009 Location: Hampshire, UK
The HS645MG puts out 133oz at 6 volts. Most look for over 100oz in an aftermarket servo, either full size or micro. I would recommend running a CC BEC though some don't think it necessary. Metal gears are also a must have. I bought an HS645MG but before I got it installed I got a bargain on an HS5955TG which puts out 333oz at 6 volts which should be bullet proof. Hope this helps. |
11-26-2010, 08:05 PM | #5 |
I have ran a ht 645 for over a season.No worries from the servo,no need for a bec either with a 645. No bec keeps your rats nest smaller and weight lower. |
11-26-2010, 09:00 PM | #6 |
Just jump it! Join Date: Aug 2008 Location: Cedar City, Utah
I like torque!! I run a JR 8711 on mine. A good servo is worth its money. |
11-27-2010, 01:41 PM | #7 |
Thanks guys for the info, my wife would like a MRC so I"m trying to figure out how much I'm going to have to spend to build one.
