11-29-2010, 09:54 AM | #1 |
Rock Crawler Join Date: Nov 2008 Location: The Lone Star State
| McTwist Mini Moonbuggy
And so it begains.... Parts List: T1E CF Mini Moonbuggy Mamba Micro Pro ESC Castle BEC Futaba 4PL Futaba receiver Blue Bird Low Profile High Torque Servo Reedy Stump Puller 19T 12T Pinion BWD HD Motor Plate BWD Motor Spacer RC Bros Zero Ackerman High Steer Knuckles RC Bros High Steer Link RC Bros lockers Front and Rear HR Alum. Tranny Gears Losi Alum. “C”s Losi Rear Lockouts Losi CVDs Mini Revo Pinion Front McTwist Underdrive Mod Rear MIP Drive shafts G-Made Axle Wideners Up Front CKRC Wide Hexes Out Back Vanquish LHs (narrowed) Rovers Crawler Innovations Softs Front and Firm Rear * = Items Subject to Change Last edited by McTwist; 08-30-2012 at 05:01 PM. Reason: Text edit |
11-29-2010, 09:56 AM | #2 |
Links built and attached.
11-30-2010, 09:16 AM | #3 |
| The doror The donor MRC with a Dark Soul Chino chasses. I picked this rig up from ncgoose in the For Sale section. The rig was in really you shape. I'll post more photos once I transplant the axles and tranny. |
11-30-2010, 09:31 AM | #4 |
Quarry Creeper Join Date: Oct 2009 Location: Athens
Look forward to seeing the rest of the build. I keep seeing these MRC's with VP wheels, it's torture |
11-30-2010, 09:45 AM | #5 |
Quarry Creeper Join Date: Sep 2010 Location: Dewsbury, UK
Great photos, good to see clear photos of a build - gives me ideas! I really like your bent delrin links. Did you make them? |
11-30-2010, 09:52 AM | #6 | |
It would be really cool if VP would make adjustable offsets for the 1.9 wheels like they have for the 2.2s. | |
11-30-2010, 09:57 AM | #7 | |
Me too. Then you can sell me yours | |
11-30-2010, 10:01 AM | #8 | |
I guess I should have pointed out what all comes in the kit from T1E.
11-30-2010, 10:03 AM | #9 |
11-30-2010, 02:03 PM | #10 |
| Getting it together
Axles and tranny mounted. Note the RC Bros steering link doesn't work with the current T1E front 4 link / servo mount. I have a mod in mind to work around this issue. I didn't like the way the rear upper links mount to the top of the 4 link plate so I moved the links to the bottom of the plate. Seems to be okay once I get it on the rock I may switch them back just to see how it effects the handling. Last edited by McTwist; 11-30-2010 at 04:51 PM. |
11-30-2010, 02:26 PM | #11 |
I wanna be Dave Join Date: Mar 2009 Location: SW Missouri
Keeping an eye on this, I have a moonbuggy coming, so am interested to see how you work out the steering.
11-30-2010, 04:49 PM | #12 |
| Servo Okay, time for a little servo action. The servo I picked is a Blue Bird BMS 705MG Low Profile. Torque At 6.0V: 7.4kg/cm , 112 oz/in Speed At 6.0V: 0.16sec / 60° at no load Weight: 34g / 1.19oz Dimensions: 42 x 21.5 x 22 mm / 1.65 x 0.85 x 0.87 inch The first picture shows the BMS705GM next to a standard servo. Note the size difference and the weight is about half. I have never ran one of these before so it will be interesting to see how it performs and holds up. I'm sure it is better than the HS225 I was running. |
11-30-2010, 04:50 PM | #13 |
Gary I havnt gotten to the rear axle yet.But I was thinking under the plate like on the front myself also.
11-30-2010, 04:57 PM | #14 |
| It just seemed strange to mount the links on top and the links hit the end of the 4 link plate nearest the chassis. Could have been that I have the Losi shocks. I think T1E recommends running the Duratrax shocks off of a Vendetta that are a little shorter. For now I am just going to limit the Losis internally. |
11-30-2010, 05:05 PM | #15 |
AKA 2G's Join Date: Feb 2006 Location: Where the wind blow's
The top rear links need tobe on top, Put spacer's if you half to. If you got the right shocks the rear top links should be parallel with the ground. Trust me.
11-30-2010, 05:59 PM | #16 |
Holmes Hobbies Join Date: Jan 2007 Location: No Where
11-30-2010, 07:33 PM | #17 |
12-01-2010, 12:43 PM | #18 |
| RC Bros steering link RC Bros High Steer Link As I stated before the RC Bros steering link will not work with the correct configuration of the front 4 link/servo mount. I moved the link holds back and in just enough to clear the steering link. I made new links that were 1cm shorter and adjusted caster with a 3mm spacer. This is all subject to change once I get it out on the rocks. |
12-01-2010, 06:13 PM | #19 |
I better not here" Man what's wrong with my truck it does'nt handle as good as Greg's" . Im just going to say you should'nt of change the link geometry. Also,I just dont understand why people want a BTA kit for there mini's??? The servo sticks out anyway. So instead of you hitting the tie rod(Whitch the tie rod acts like a ramp) you hit the sevo. I used 1/4 delrin because it flex'es alittle when i ram it into a rock that i want to get over. Look at my picture and look at your's witch one do you think has the smoothest aproach angle?? Im just try to help you have a great handling truck. |
12-01-2010, 06:30 PM | #20 |
Gotta admit i'd go for a BTA setup if i could. Problem i've had with having the steering linkages up front is, when they get hung up (on the steering linkage), when i steer it knocks the truck off line. The BTA is out the way and also less likely to get damaged |
