12-19-2010, 10:30 AM | #1 |
Newbie Join Date: Aug 2010 Location: spok
| lipo-cutoff woes
Was putting lipo cutoff(novak 2s)on the boys crawler yesterday, i cannot get it to program. lights up with red like it says it will, but then never blinks green and goes back to red... i have tried re-programming the stock ESC, but it will not do its deal with the Cutoff attached, and does nothing different without it attached.. although the smoking sparking mess from the first ESC attempt could have something to do with it......the cutoff still lights up the way it should at first... TOAST?cheers, b |
12-20-2010, 12:37 AM | #2 |
for serious?i can build anything,but not an electronics guy....
12-20-2010, 07:31 AM | #3 |
It sounds like you do not have the neutral position set properly. Here are the instructions in case you dont have them: http://www.teamnovak.com/download/in...smart_stop.pdf |
12-20-2010, 01:34 PM | #4 |
yeah, followed those instructions to a T.......nada, zip, zilch, nothing....goes solid red, but doesna blink green then go red again.i'm stumped.cheers, b edit:just did it for like the 30th tmie and it worked.i don't know what the hell was happening.cheers!!now he won't be ruining our batteries Last edited by monstaru-poki; 12-20-2010 at 01:52 PM. |
12-20-2010, 01:36 PM | #5 |
It sounds like it's time for you to give Novak a call. |
12-20-2010, 01:54 PM | #6 |
Is your battery charged? Sounds like your battery may be out of range when you plug it in...
12-20-2010, 02:21 PM | #7 |
i got it, edited up there^.....thanks.cheers, b
