Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Mini-Rock Crawler
Thread: Tech question...
Old 12-26-2010, 08:01 PM   #1
Default Tech question...
Just picked up brushless MRC in trade...It was working good, but after a couple runs I found I am not getting power from the rear wheels. If I have the rig off the ground they seem to move fine, but when crawling up hill only the front is pulling. I can stop the rear wheels easliy with 1 finger? Any ideas?
Marc P is offline   Reply With Quote
Old 12-26-2010, 08:02 PM   #2
Probably a broken stock plastic locker. Tear open the axle and check it out...
JeremyH is offline   Reply With Quote
Old 12-26-2010, 08:07 PM   #3
or the center locker (gear box) or the set screws in the driveline
rockslyder is offline   Reply With Quote
Old 12-26-2010, 08:09 PM   #4
Seems to be in the transmission. I checked the set screw first, I can hold the rear driveshaft with the same result.
Old 12-26-2010, 08:30 PM   #5
What a weak design...the rectangle shaped wedge where the metal shafts go into the main gear for the rear shaft is now rounded.
Old 12-26-2010, 08:33 PM   #6
Without weak designs, there would be no need for aftermarket or replacement parts.......
Scottmisfits is offline   Reply With Quote
Old 12-26-2010, 10:32 PM   #7
they where not setup for aftermarket brushless , with a stock motor they would last longer
